FS - Lightly used SMART system for XEDE
Old Aug 12, 2005 | 06:14 AM
freedom's Avatar
I found similar results but that said I'm not in a region of the country when Shiv shows his face very often. So in my mind SMART is my virtual Shiv, which I believe is the concept for the system.
On the other hand if I had a hand tuned map that was worth anything I wouldn't be as interested in the SMART hardware. So I can see where you are coming from.
Originally Posted by EVIL_EV0
This is correct. I have a custom map on my XEDE and I didn't benefit much from the SMART. I logged with smart and without smart and there was next to no difference. I also logged with a baseline map and smart and there was a difference but I am not running a standard issue baseline map.
Old Aug 12, 2005 | 06:46 AM
Smogrunner's Avatar
Originally Posted by Zeus
I'm real antsy about buying SMART right now, but for the price, I sent you a PM.
The whole SMART upgrade is a little to "fluid." However, I just got my car running and I am looking forward to the whole v3 upgrade with smart.
Old Aug 12, 2005 | 06:53 AM
Noize's Avatar
EvoM Administrator
The reason I'm excited about SMART is that it will be adaptable when the weather changes or when you fill up at a station whose premium isn't as good as another when you're traveling, etc.
Old Aug 12, 2005 | 07:44 AM
EVIL_EV0's Avatar
If you have a baseline map that hasn't been custom tuned you will probably see some gains with smart.....espeically if you are a risk taker and you want to run the bleeding edge of performance AFR and timing.
I have since removed my SMART and I noticed the partial throttle changes more than the WOT changes. In the months to come I imagine SMART will be enhanced with more elaborate algorithms and upgrades to make it even more beneficial. Even though I sold my unit I seriously hope to see some dyno's showing nice gains with SMART.
Old Aug 12, 2005 | 08:35 AM
freedom's Avatar
The fuel switch map doesn't permit the smart fuel adjustments to occur until a very high load (e.g. WOT), thus if you felt partial throttle changes I would suggest it was because timing was pulled when knock was detected.
