Can clients without SMART read knock?
Old Aug 12, 2005 | 07:46 AM
EVIL_EV0's Avatar
Just curious how if the NON-SMART V3.2 clients are able to log knock.
Any information would be greatly appreciated.
Old Aug 12, 2005 | 08:36 AM
freedom's Avatar
I really think you need to knock buffer to do that.
Old Aug 12, 2005 | 09:17 AM
donour's Avatar
What we've been calling knock is actually a buffered noise signal. So, as freedom said you need the hardware to read the signal.
d
Old Aug 12, 2005 | 11:09 AM
EVIL_EV0's Avatar
I'm not so sure about that.......the factory ECU reads knock.....so we should be able to interpret that signal without the buffer. Hell the 92 DSM ecu could spit out degree's of knock so should the EVO ECU.
Old Aug 12, 2005 | 11:16 AM
donour's Avatar
But how would you wire it up? As it stands, non-SMART xedes only know about knock attenuation state, not noise level.
d
Old Aug 12, 2005 | 11:42 AM
freedom's Avatar
Well internal to the ECU they are processing the knock micrphone's output. Thus if one has a software patch to the ECU such as exists for the DSM's, you could have the same capability.
That said the knock microphone needs amplification to permit the Xede to digitize the signal. Also the sample rate of the Xede might not be high enough to capture knock events (unless you are lucky). It appears that the knock buffer is more than an amplifier from the little I played with it.
Old Aug 12, 2005 | 11:43 AM
freedom's Avatar
Concur.
I think all that attenuation is just that. They load down the knock microphone's input to reduce the signal seen by the ECU. Thus this is an ouput from the Xede, not an input.
d
Old Aug 12, 2005 | 12:00 PM
EVIL_EV0's Avatar
Old school tuners have been hooking tapping the knock sensor for years.....without a buffer.
If the sensor is hearing noise and the background noise increases roughly proportionally with rpm it should be easy to tap into the signal and read knock.
The EVO ECU dynamically adjusts its background noise threshold so it knows when an amplitude event (knock) is out of spec and then pulls timing.
This data should be able to be logged. You dont really need to tap wires but rather read data from the ECU.
Old Aug 12, 2005 | 12:14 PM
donour's Avatar
Again, how would you do this without splicing? I don't doubt you _could_ prep the knock signal and feed it to an xede analog in. I just doubt any of us could do it any easier than buying chiptorque's....err, vishnu's knock buffer and hooking it up.
d
Old Aug 12, 2005 | 12:29 PM
EVIL_EV0's Avatar
Well there is a knock sensor wire we can tap into.....people use this for AFC knock monitoring so why cant we use it without a buffer?
"The AFC's purple wire (knock sensor) should be connected to the white wire that is the 4th wire from the right on the top row of wires."
Old Aug 12, 2005 | 12:40 PM
donour's Avatar
As freedom said, you'd have to amplify the signal to the 0-5v range that the xede uses for it's analog ins.
d
Old Aug 12, 2005 | 12:41 PM
shiv@vishnu's Avatar
It really depends on the circuitry in the S-AFC. Some of the monitoring devices I tried prior to designing the knock buffer robbed the ECU of too much of the signal-- causing the car to knock terribly. Just food for thought....
shiv
Old Aug 12, 2005 | 12:46 PM
EVIL_EV0's Avatar
Okay lets say its not XEDE specific........what device other than an S-AFC would be able to interpret that signal? A pocketlogger of some sort????
Also if the ECU is reading this signal.....then we should be able to optain those value directly via software shouldnt we
Old Aug 12, 2005 | 01:05 PM
donour's Avatar
What software?
d
Old Aug 12, 2005 | 01:08 PM
SuperHatch's Avatar
A Pocketlogger can't monitor knock directly, only ignition timing. You'd be able to see when the ECU pulled timing, and infer where the knock is, but never see the true knock value.
- Steve
