Can someone look into my data logs and help me out.
Well it seems my car is just not pulling enough in 4th gear to give the mph that I am supposed to be getting. I used the Xmap3 data log to record my 2-3-4 gear pulls. Here it is.
Log started at 8/20/2005 12:52:41 PM
RPM/100,Timing Advance,AN0 in,AN0 out,AN1 in,AN1 out,AN2 in,AN2 out,Knock,Marker
25,-0.2,66.5,66.4,66.5,66.4,66.5,65.7,1,0
26,-12.8,0.195,0,66.5,0,66.3,0,0,0
29,-12.8,0.195,0,0.195,0,66.3,0,0,0
33,-0.2,66.5,66.4,66.5,66.4,66.5,65.7,1,0
34,-12.8,66.5,66.4,0.195,66.4,66.5,65.7,0,0
38,-0.2,66.4,66.4,66.5,66.4,66.6,65.7,1,0
40,-0.2,66.4,66.4,66.5,66.4,66.6,65.7,1,0
41,-0.2,66.5,66.4,66.5,66.4,66.3,65.7,1,0
43,-0.2,66.5,66.4,66.5,66.4,66.3,65.7,1,0
44,-0.2,66.5,66.4,66.5,66.4,66.3,65.7,1,0
45,-0.3,66.5,66.4,66.5,66.4,66.3,65.7,1,0
46,-0.6,66.5,66.4,66.5,66.4,66.4,65.7,1,0
48,-0.8,66.5,66.4,66.5,66.4,66.4,65.7,1,0
51,-1.1,66.4,66.4,66.5,66.4,66.3,65.7,1,0
52,-1.1,66.4,66.4,66.5,66.4,66.3,65.7,1,0
54,-1.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
55,-1.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
57,-1.6,66.5,66.4,66.5,66.4,66.3,65.7,1,0
59,-1.8,66.5,66.4,66.5,66.4,66.3,65.7,1,0
60,-2.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
62,-2.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
63,-12.8,66.5,66.4,66.5,66.4,66.4,65.7,0,0
69,-2.4,66.5,66.4,66.5,66.4,66.4,65.7,1,0
70,-2.5,66.5,66.4,66.5,66.4,66.6,65.7,1,0
72,-2.5,66.5,66.4,66.5,66.4,66.6,65.7,1,0
73,-2.5,66.5,66.4,66.5,66.4,66.6,65.7,1,0
74,-2.5,66.5,66.4,66.5,66.4,66.6,65.7,1,0
75,-0.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
71,-0.5,66.5,66.4,66.5,66.4,66.3,65.7,1,0
68,-2,66.5,66.4,66.5,66.4,66.5,65.7,1,0
63,-2.1,66.5,66.4,66.5,66.4,66.5,65.7,1,0
54,-1.1,66.5,66.4,66.5,66.4,66.5,65.7,1,0
57,-1.4,66.5,66.4,66.5,66.4,66.5,65.7,1,0
55,-1.5,66.5,66.4,66.5,66.4,66.5,65.7,1,0
56,-1.3,66.5,66.4,66.5,66.4,66.5,65.7,1,0
58,-1.6,66.5,66.4,66.5,66.4,66.6,65.7,1,0
61,-2.1,66.5,66.4,66.5,66.4,66.6,65.7,1,0
62,-2,66.5,66.4,66.5,66.4,66.6,65.7,1,0
63,-2.1,66.5,66.4,66.5,66.4,66.6,65.7,1,0
64,-12.8,66.5,66.4,66.5,66.4,66.4,0.195,0,0
66,-2.3,66.5,66.4,66.5,66.4,66.4,0.195,1,0
69,-2.4,66.5,66.4,66.5,66.4,66.3,65.7,1,0
70,-2.5,66.5,66.4,66.5,66.4,66.3,65.7,1,0
71,-2.5,66.5,66.4,66.5,66.4,66.5,65.7,1,0
72,-2.5,66.5,66.4,66.6,66.4,66.5,65.7,1,0
72,-2.5,66.5,66.4,66.5,66.4,66.5,65.7,1,0
73,-2.5,66.5,66.4,66.5,66.4,66.5,65.7,1,0
73,-2.5,66.5,66.4,66.5,66.4,66.3,65.7,1,0
71,0,66.5,66.4,66.6,66.4,66.3,65.7,1,0
69,-2,66.5,66.4,66.5,66.4,66.4,65.7,1,0
65,-2.2,66.5,66.4,66.5,66.4,66.4,65.7,1,0
58,-1.1,66.5,66.4,66.5,66.4,66.3,65.7,1,0
56,-1.2,66.5,66.4,66.5,66.4,66.3,65.7,1,0
56,-1.3,66.5,66.4,66.5,66.4,66.6,65.7,1,0
57,-1.4,66.5,66.4,66.6,66.4,66.6,65.7,1,0
57,-1.5,66.5,66.4,66.5,66.4,66.4,65.7,1,0
58,-1.6,66.5,66.4,66.5,66.4,66.4,65.7,1,0
58,-1.7,66.5,66.4,66.5,66.4,66.6,65.7,1,0
58,-1.8,66.5,66.4,66.5,66.4,66.6,65.7,1,0
59,-1.8,66.5,66.4,66.6,66.4,66.8,65.7,0,0
60,-2.1,66.5,66.4,66.6,66.4,66.8,65.7,1,0
61,-2.1,66.5,66.4,66.5,66.4,66.5,65.7,1,0
61,-2.1,66.5,66.4,66.6,66.4,66.5,65.7,1,0
61,-2.1,66.6,66.4,66.5,66.4,66.7,65.7,1,0
62,-2.1,66.6,66.4,66.5,66.4,66.7,65.7,1,0
62,-2.1,66.5,66.4,66.5,66.4,66.5,65.7,1,0
63,-2,66.5,66.4,66.5,66.4,66.5,65.7,1,0
64,-2.2,66.5,66.4,66.5,66.4,66.5,65.7,1,0
64,-2.2,66.5,66.4,66.6,66.4,66.5,65.7,1,0
64,-2.2,66.5,66.4,66.5,66.4,66.6,65.7,0,0
66,-2.3,66.5,66.4,66.6,66.4,66.6,65.7,1,0
66,-2.3,66.5,66.4,66.5,66.4,66.6,65.7,1,0
67,-2.4,66.5,66.4,66.6,66.4,66.6,65.7,1,0
67,-2.4,66.5,66.4,66.6,66.4,66.5,65.7,1,0
67,-2.4,66.5,66.4,66.5,66.4,66.5,65.7,1,0
68,-12.8,66.5,66.4,66.5,66.4,66.3,65.7,0,0
70,-2.5,66.6,66.4,66.6,66.4,66.7,65.7,1,0
70,-2.5,66.6,66.4,66.6,66.4,66.7,65.7,0,0
71,-2.5,66.5,66.4,66.5,66.4,66.6,65.7,1,0
72,-2.5,66.6,66.4,66.6,66.4,66.4,65.7,1,0
0,-12.8,66.6,66.4,0,66.4,66.4,65.7,0,0
74,-2.5,66.5,66.4,66.6,66.4,66.4,65.7,1,0
73,-2.1,66.5,66.4,66.6,66.4,66.4,65.7,1,0
73,-1.9,66.6,66.4,66.6,66.4,66.6,65.7,1,0
0,-12.8,66.6,66.4,0,66.4,66.6,65.7,0,0
72,0,66.5,66.4,66.6,66.4,66.6,65.7,1,0
71,0,66.5,66.4,66.6,66.4,66.6,65.7,1,0
71,0,66.5,66.4,66.6,66.4,66.5,65.7,1,0
69,0,66.5,66.4,66.6,66.4,66.5,65.7,1,0
68,0,66.6,66.4,66.6,66.4,66.7,65.7,1,0
67,0,66.6,66.4,66.5,66.4,66.7,65.7,1,0
66,0,66.6,66.4,66.5,66.4,66.5,65.7,1,0
65,0,66.6,66.4,66.5,66.4,66.5,65.7,1,0
64,0,66.6,66.4,66.5,66.4,66.7,65.7,1,0
63,0,66.6,66.4,66.6,66.4,66.7,65.7,1,0
62,0,66.5,66.4,66.6,66.4,66.6,65.7,1,0
60,0,66.5,66.4,66.6,66.4,66.6,65.7,1,0
59,-0.1,66.5,66.4,66.5,66.4,66.6,65.7,1,0
58,-0.1,66.5,66.4,66.6,66.4,66.6,65.7,1,0
57,-0.1,66.5,66.4,66.6,66.4,66.4,65.7,1,0
55,0,66.5,66.4,66.6,66.4,66.4,65.7,1,0
55,0,66.6,66.4,66.6,66.4,66.4,65.7,1,0
53,0,66.6,66.4,66.5,66.4,66.4,65.7,1,0
52,-12.8,66.5,0.195,66.6,66.4,66.4,0,0,0
Any help would be apreciated.
I tried one change after I did this data logging with advice from Andrew (Dyno4mance) to lower my boost table 5 clicks after 5000 rpms but that only resulted in 104.xx mph.
PS. Sorry Andrew for taking up your time, I am kind slow with all this graphs but I am learning. Sorry once again.
Here is are the numbers of best run for Evo vs STI shootout on august 20:
60' 1.909
330 5.420
1/8 8.345
mph 85.99
1000 10.889
1/4 12.992
mph 105.75
As you can see I am not getting that much in 4th gear.
Just a little comparesion, Superhatch who was trapping also about 85.xx in the 1/8 but was ending up with 113mph. Me and him almost have the same mods.
60' 1.909
330 5.420
1/8 8.345
mph 85.99
1000 10.889
1/4 12.992
mph 105.75
