Vischnu 3037 Turbo kit
This only gets better by the post; I would have sworn someone like yourself would be making your own, much less asking what the difference is, with your merits and all. 301, 321 that would be the difference in strength, 301 not as strong as the 321.
COMMENTS REMOVED. CLEAN UP YOUR LANGAUGE OR TAKE A HIKE!
Speedlimit...
Originally Posted by Supernaut
Jesus Christ man does your neck hurt from sucking your own dick all day? Jesus I KNOW what 301 and 321 is, just wondering WHY AMS (IMHO the leader in Turbo kit quality and fitment) uses 301 Vs. Vishnu on 321. You know God damn fawking well it has nothing to do with the steel and you must look at the welds 1st. AMS has BY FAR the best welds I have ever seen and their “LOWELY” 301 SS has yet to fail.
The most likely reason AMS (and I'm guessing here) uses thick 304 SS is that it is "good enough" and it is both easier to work with and less expensive. The most likely reason Vishnu uses 321 (again taking an educated guess here) is that 321 is theoretically better suited for high temperature application such as exhaust manifolds, and if anything else, Shiv and Co. are probably even bigger perfectionists than AMS.
l8r)
AMS uses 304 SS thick wall tubular header.
l8r)
__________________
l8r)
__________________
aaaaaaaaaaaaaaaaa-THANK YOU
Hey Smogrunner.
On that Dyno, I know which is the GT35R, but which is yours again?
Thanks, I believe you are running or ran the same kit as Evo_Chip?
If you want a pump gas monster, my recomendation would be a 3071 with 280 cams. The 3071 is a bit stronger on pump gas than the 3037. With that turbo, I think that 120 trap speeds would be doable on 93. As for 123....who knows.
