xede install?
Old Sep 6, 2005 | 01:00 PM
eling99's Avatar
xede install?
i just want to make sure im getting this right?
1. the blue wire will go to the stock harness clip?
2. do you connect the light green wire with the brown wire and then use the shrink wrap?
3. what do i do with the red and black wire?
4. i got the 91 stage 0 and 91 stage 1 maps. Do you think its on the stage 0 map?
Old Sep 6, 2005 | 01:11 PM
shivaswrath's Avatar
dude, detailed pics as this comes along would be great, since I'm still tossing the idea between a piggy back system like this versus a Works P2 flash. . . .if you unplug everything, does the ECU reset itself back to stock and you're good to go??
Old Sep 6, 2005 | 01:27 PM
Ninj0x's Avatar
http://www.vishnutuning.com/xede_support_evo.htm Install instructions are half way down the page.
Old Sep 6, 2005 | 01:43 PM
eling99's Avatar
i already checked that out!!! not really understanding it so i just want to make sure!!
Old Sep 6, 2005 | 09:49 PM
eling99's Avatar
nobody wants to help me?
Old Sep 7, 2005 | 05:03 AM
Dyno4mance's Avatar
you are correct on the boost wires ....(that shrink wrap is no good...get your own )
the wire/s with loop/s on the end are ground/s
the red and black wire you describe is two wires and they are used for map switching..
when they are joined together you are in the second map area.....I always put a switch on the end...
Hope this helps
Old Sep 7, 2005 | 06:18 AM
eling99's Avatar
Hope this helps
so with the the black and red wire...put a switch on it so i can toggle back and forth? How do i know which one is 91 stage 0 or 91 stage 1( i didnt get 100 stage)?
Old Sep 7, 2005 | 10:21 AM
Dyno4mance's Avatar
It depends what maps are loaded...Please refer to the "Xede Support" section of Vishnu's website
Old Sep 7, 2005 | 02:31 PM
eling99's Avatar
does anybody have a pic of this switch?
Old Sep 7, 2005 | 03:36 PM
gashero's Avatar
you can get any switch at radio shack. I just use an insulated male and female plug instead. this way it wont confuse you which one is which map. unplug =map0 . plug together = map1
Old Sep 7, 2005 | 04:01 PM
eling99's Avatar
i suck at electronics...what do u mean by plug together? arent the wires togther already!!! so if i want to run stage 0, just leave the wires alone?
Old Sep 7, 2005 | 04:16 PM
urBan_dK's Avatar
What he means is that when the red and black wire are NOT touching map0 is used and when they touch map1 is used. Installing a switch (or male/female connection) between the two wires will allow you to either complete the circuit for the second map or leave it broken for the first map.
Old Sep 7, 2005 | 04:20 PM
eling99's Avatar
Originally Posted by urBan_dK
What he means is that when the red and black wire are touching map0 is used and when they touch map1 is used. Installing a switch (or male/female connection) between the two wires will allow you to either complete the circuit for the second map or leave it broken for the first map.
k..u said when they touching map 0 is used, and then u say when they touch map 1 is used?
so im pretty much screwed? man..this sh*t is confusing me!!!
Old Sep 7, 2005 | 04:31 PM
urBan_dK's Avatar
When they are NOT touching, map 0 is used (you called it your "Stage 0" map). So if you want to use only this map, cover the ends of the wires with electrical tape to prevent the wires from touching. If you want to use map 1, attach the wires together. If you want to use both, install a switch.
EDIT: I discovered my first post had an error, it is corrected.
Old Sep 7, 2005 | 04:53 PM
eling99's Avatar
got it..thanx a lot!!!
