Launch Controll and Meth injection
Old Nov 17, 2005 | 11:23 AM
Cajun Power's Avatar
Shiv/Vishnu guys,
Please add launch control and a meth/alky injection to my maps.
I will be running the AMS kit with no map sensor. Using the Xede to do the progressive control. Just set the Launch NLTS to 6000 and I will adjust from there.
Attached are my maps from the recent dyno4mance dyno day.
I would like to use the 93 on blank 0 with a 93+alky on blank 1. I included my 96 oct map if that helps any. I would also like to have a 96+alky for track days that I can just upload as needed.
Here is a stupid question on my part. I thought you had to turn the car off and then switch to the other map. Can you switch on the fly? I have always shut down to switch maps. Maybe I am just stupid?
Cajun Power
PM me for direct email if needed.
File Type: zip
Old Nov 17, 2005 | 03:07 PM
cooter's Avatar
Switching on the fly is no problem. I've never tried it while in open-loop, however (only at idle/cruising).
Old Nov 17, 2005 | 04:39 PM
smokedmustang's Avatar
I flip it on the go also. clutch in, idleing at whatever speed. No problems.
Old Nov 18, 2005 | 05:52 AM
Thanks Cooter/Smokedmustang. That has always been one of those... I think I can, but just to be safe, I better not... things.
Vishnu Guys - can u hook a brother up with some maps?
