need help, no boost control!!!
Old Dec 3, 2005 | 07:27 PM
NEMES!S's Avatar
05 running 93oct v330 non smart enabled map w/smart system
Ok I disabled smart, 0's in the smart tables, I have no boost control. spring control at 12.5 psi
used a volt meter chased wires from wastegate sol to ECU harness, checked ok,(yes the correct light green wire is in use, and yes removed restrictor pill) tried to 0 smart boost map, 50.2 was what it put in all the cells, no help. manually installed 0's in all cells, no help
manually installed 100 in all the cells, no help. used several different smart boost cell values, no help
Someone plese help!!!
Old Dec 3, 2005 | 07:50 PM
jrsimon27's Avatar
try uploading a new program thats smart enable to your xede! visit vishnu site
Old Dec 3, 2005 | 08:03 PM
JTB's Avatar
JTB
What is the Xede light doing? Is it solid green or flashing?
Have you tried reconnecting the stock ECU? If so, what sort of boost were you seeing?
Have you logged anything? One of the things that you can log is the waste gate solenoid output.
Old Dec 4, 2005 | 05:23 PM
NEMES!S's Avatar
light is green, solid, yes on Ecu, it boosts to 25 peak, 22 normal
using live data display I watch wastegate % 97% under heavy load
but only 12.5 psi I have 2 boost gages both say the same
where is the high speed data log file stored? what directory
Old Dec 4, 2005 | 05:29 PM
shiv@vishnu's Avatar
If it is solid green, then the XEDE is online and doing its thing. It really sounds to me like you pulled the wrong green wire (there is two of them). One is boost control. The other is idle control.
Did you hook up the XEDE's ground?
shiv
Old Dec 4, 2005 | 07:21 PM
NEMES!S's Avatar
shiv
I chased the wastegate sol wire with a volt meter to the ECU harness, its correct.
I used the wire closest to the keyway marks of the connector
I hooked it up to the place described in the instructions and pictures(the black wire with a ring lug right?)on the ecu mount bolt.
