FULL BOOST AT 6000 RPM? only
Old Dec 22, 2005 | 08:55 AM
NEMES!S's Avatar
Full Boost At 6000 Rpm?
when should boost peak out?(rpm and load), I dont get full 20 psi till around 6000 rpm, in any gear at any load, is that right?
05 w/ smart 93 oct v330
adjusting boost table only has an adverse effect(no increase at all)
at any other time during rpm increase it reads about 12-13 psi then slowly increases to 20-21 once ive past the 5000 rpm mark and holds steady through 7000 rpm
my mid range is lacking or seems like it through the lower RPMs
good top end though.
Old Dec 22, 2005 | 11:03 AM
dude's Avatar
I think you may have connected the wrong green boost wire to your Xede. Sounds like it's not controlling the WG at all and you're only getting 12 psi as a result.
Old Dec 22, 2005 | 11:10 AM
Dustin@Vishnu's Avatar
Will you please post your map? I want to see if I can make some changes for you.
Old Dec 22, 2005 | 11:39 AM
Vishnu_Evo8's Avatar
i got full boost on stock turbo arround 3k or less i cant remember but if its way higher then you installed someting wrong.
Old Dec 23, 2005 | 01:50 PM
NEMES!S's Avatar
Ive check the install at least a 5 times minimum and verified the correct green wire using meters and wiring chasing equipment
I also add a ground wire to the termination point of the XEDE ground along with all the sensor grounds
termination and ground pounding have been done several times
Dustin the map is one I made up on my own I know that might have a lot to do with it but I never could get a V330 version from anyone else
I NEED MORE MODS!!!!
Here's what I'm using
File Type: zip
Old Dec 23, 2005 | 01:59 PM
MANGOOK's Avatar
Full boost no later then 3500RPM
Old Dec 23, 2005 | 03:06 PM
jrsimon27's Avatar
i think the problem is your boost table put in it 100%
Old Dec 23, 2005 | 03:37 PM
Try adding another load row in the boost map, so it reads: 10,13,15,16. I have a feeling that your car doesnt make enough load to triger the 15% load cell. As a result, the boost controler doesnt turn on until much later in the RPM range.
You can also test this by filling in 100s after 2500RPM in the bottom two rows.
Old Dec 23, 2005 | 03:42 PM
shiv@vishnu's Avatar
yeah... what he said!
Old Dec 23, 2005 | 04:08 PM
NEMES!S's Avatar
Thanks for the input guys
Dustin does the map look OK otherwise?
Appauldd
Feb 15, 2017 07:05 AM
Kaveeth
Mar 9, 2015 03:03 AM
Chamama
15
Feb 12, 2013 08:28 AM
pltek
31
Aug 22, 2009 08:06 AM
Nuked
Jun 2, 2008 06:32 PM
