How To: Tuning Ignition Timing for Cams with XEDE
Old Dec 25, 2005 | 06:46 PM
HiVoltEVO8's Avatar
Guys/ Gals,
Thought there might be some people interested in my results from tuning the ignition timing for a better idle. Please see the attached file.
Let me know if this was helpful or not.
Merry Christmas!
HiVolt EVO8
File Type: pdf
Old Dec 26, 2005 | 02:10 PM
HiVoltEVO8's Avatar
Update
Well,
I have been running around with the map changes expressed above. The car throws PO300 codes now...........but I can deal with that right now. The one thing that I cannot deal with is a slight "stuttering" that appears every once in awhile. The funny thing is that this stuttering appears when the car is operating in a part of the map that does not have advance in it. If I lift the throttle and reapply it, the stuttering goes away. This is definately an ignition related issue.
It seems that the ECU does not like advancing the timing. I am not sure if this is a CAS replication issue or what. However, I cannot determine why this issue would arise only in advanced timing situations. I also realize that advancing the timing is predictive algorythms in lieu of replication algorythms.
I am really interested in Shiv's comments regarding this. If I cannot resolve this issue, I feel that I may proceed with a different form of engine management. I do not like AEM due to their injector drivers. I am strongly considering the Power FC route.
Old Dec 26, 2005 | 02:58 PM
Rushin's Avatar
Have you tried reducing the area that has advanced timing? For example make it zero out by 1300 rpm and up to only 18% load? I have 272's and it only idles rough when its below 1000 rpm.
I have also experienced that stutter when I tried advancing timing in low load cells.
Old Dec 26, 2005 | 04:53 PM
HiVoltEVO8's Avatar
Rushin,
Thanks for the assistance. I will give that a try and see if it will reduce or eliminate the stuttering problem.
HiVoltEVO8
Old Dec 26, 2005 | 06:49 PM
Rushin's Avatar
That's an interesting experiment you're doing. Has anyone else tried this successfully?
Old Dec 26, 2005 | 07:42 PM
HiVoltEVO8's Avatar
Not that I know of. However, I am sure that this is what has been done with the idle flash for camshafts. I am just trying to use XEDE to do the same thing. Hopefully, this works.
Old Dec 27, 2005 | 02:10 AM
Rushin's Avatar
I tried to adjust the timing earlier today. I set it to +5 in only 4 cells - loads 2-10 and 500-1000 rpms.. seems to work ok with no po300. The idle is even but still rough. Not bad
Old Dec 27, 2005 | 06:09 AM
HiVoltEVO8's Avatar
+5 degrees is about the breaking point that started to make a difference on mine. The closer I got to 9, the more vacuum and better idle was produced. I have implemented your recommendations, but I have not driven the car enough to know if the PO300 issue will pop back up. Only time will tell
Old Dec 27, 2005 | 06:33 AM
EvilBlueEvo8's Avatar
yeah this is interesting! keep us posted!
Old Dec 27, 2005 | 03:13 PM
HiVoltEVO8's Avatar
Still have PO300
Well Guys,
I changed the mapping to where the advance tapered of quickly to 1500 RPM. I still get the PO300 CEL. I am going to try just 4 cells this time like Rushin.
Old Dec 30, 2005 | 07:21 PM
HiVoltEVO8's Avatar
I tried just advancing the timing in the 4 cells that the car operates in at idle. Unfortunately, the car still is throwing the PO300 codes. This is beginning to seem like a lost cause. Let me rephrase it, my car is running the best that it ever has at idle. I have GSC 272 cams, Cam gears set at -3/-3, constant 800-850 RPM idle, and 15" Hg vacuum. The only issue is that it is throwing the PO300 codes.
I am going to try an experiment with my OBDII scanner and leave it installed in the car during driving to see if it eliminates the issue. Just a hunch since the SMART system incorporates a C-reader, which should do the same thing.
I will post back here when I have results.
Old Dec 30, 2005 | 07:33 PM
Rushin's Avatar
Nice.. hopefully you can get rid of that annoying po300. As for me I like the lopey idle
