Any Meth runners NOT connected to XEDE?
I cant get answers on this, and besided starting a thread that says "I am having Shiv's BABY!" hopefully someone will look in and help me!!
I have the AMS (Alkycontrol) setup, and am running it thru the MAP sensor and the Voltage regulator. Is there a way yet to hook it up to the XEDE? The Alky kit to bypass the MAP and Voltage regulator?
I havent seen this bought up, except for Cajuns mention of it. Am I alone on this, awaiting further reasearch ? Or should I just keep it the way it is? Thanks in advance!
I use my Aquamist water injection through a MAP sensor. I could hook it up to the XEDE, but it would work the same way (Off at low loads and on at high loads). Does the AMS kit have a progressive controller?
One box, with the 2 white knobs,
and one box with a large blue knob
So are you saying that the way it is, is OK, and not needed to run thru the XEDE?
You don't need to run it through the XEDE. Just setup the map sensor to spray at 16 or whatever psi and tune away. Just be careful.
The progressive unit will work similar to what the XEDE would do. The XEDE will have the new "lean protect" feature one of these days. Then you can adapt it to the XEDE later.
You don't need to run it through the XEDE. Just setup the map sensor to spray at 16psi or whatever psi and tune away. Just be careful.
If you have SMART watch the SMART timing like a hawk while you increase the boost. Of course, make sure you kit is working properly.
i'll be adding my smc meth kit to the evo in the spring but i will not be running it threw the xede. like it was already said, i'm just going to set my progressive controller and then tune around it with the xede.
Originally Posted by smokedmustang
Great Idea, I will give you my feedback if you want it!
definitely. your car is actually pretty close is what my car is going to be around may. minus the tme turbo and with 272s instead of 280's. i'd love to see some dyno graphs of your car if you have them. thanks.
