couple of smart questions for an upcoming install
Old Jan 18, 2006 | 04:34 PM
sandm's Avatar
gettin ready to start installing my xede and smart. have a few questions prior to starting.
is there a plug/play harness for the smart system? I have seen a few posts that seem to indicate there is one on the way...
Where do I tap the dp for the innovate o2 sensor? I have a helix dp/hf cat and an rmr exhaust? I am removing the whole downpipe to install as I am also doing a 10.5 hotside at the same time and have access to a 4post lift
thanks for the responses and looking forward to dumping my dynoflash for xede and some real adjustability
scott
Old Jan 18, 2006 | 04:39 PM
jj_008's Avatar
No plug n play yet, but the wiring is pretty easy. As for a wideband bung, I have mine located on the side of the DP.
Old Jan 18, 2006 | 04:42 PM
sandm's Avatar
how far down from the o2 housing?
Old Jan 18, 2006 | 04:44 PM
jj_008's Avatar
Mine is by the rear hanger. I have also used it in the rear O2 sensor bung w/ no issues (I have no cat). My readings have been the same in both places.
Old Jan 19, 2006 | 10:24 AM
sandm's Avatar
thanks. will install it in the same place.
Old Jan 19, 2006 | 11:33 AM
Ludikraut's Avatar
Read the SMART installation instructions: http://www.vishnutuning.com/Smart/getting_started.htm
Everything you should need to know, including the bung placement.
l8r)
Old Jan 19, 2006 | 12:14 PM
sandm's Avatar
thanks
