Installing XEDE harness
Old Mar 8, 2006 | 01:41 PM
BluByWho's Avatar
Well I just read thru the install guide on the Vishnu website, I have a few questions regarding the other wires.
Blue Wire -- Boost control on ECU harness (goes in place of green wire)
Brown Wire coming of harness next to blue wire -- Plugs into green wire from ECU
Black Wire by blue wire - Ground
Red wire & Red wire w/ black stripe coming off harness -- No Idea
Second Black wire coming of harness next to the above wires -- No idea
Old Mar 8, 2006 | 01:54 PM
Bexa20's Avatar
Originally Posted by BluByWho
Brown Wire coming of harness next to blue wire -- No Idea
I don't recall exactly but I think this Brown wire is a loop for the green (boost) wire that you removed from the ECU (yellow) connector. So you take the green (female) wire out from the ECU connector you plug in the Blue one in its place, and the green (female) you connect with the brown (male)
This wire is for the second map bank if you decide to have one. If not leave them disconnected and you will use only one bank, if you decide you want to have two banks, simply connect both wires to activate the second bank
That should be your second ground wire. Both ground wires are finished with the connectors that you can tight around one of the screws that hold the ECU
Old Mar 8, 2006 | 01:58 PM
BluByWho's Avatar
Awesome I should be good to go, I'll have an update in half an hour
Old Mar 8, 2006 | 07:31 PM
evo-boy's Avatar
half an hour my a**, just kidding, good luck, i bought mine used and someone decided to clip the wires for the boost controller off because they didnt need them (thanks), so now i have to send the thing in and have it fixed, but the install is not that hard it harder to work the computer than to install the xede
