Alright I think I am losing it..
Old Mar 8, 2006 | 09:39 PM
Agent-Smith's Avatar
I have tried 4 times now to add a boost control map to my current map. I based the map off the template for smart. All the load, input, output vars, scaling (absolute), 0-100% all of that is correct.
Step on gas - all the car does is bog; even if I have the entire table 0'ed out.
help me!
Old Mar 8, 2006 | 09:49 PM
shiv@vishnu's Avatar
Something is wrong with the map you made. Post it up (in zip file) and let's look at it.
Old Mar 9, 2006 | 07:17 AM
Alright heres the map for the xm3.
File Type: zip
Old Mar 9, 2006 | 09:12 AM
Fixed. See attached map. The output variable in your SMART fuel map was incorrect. It should be set to Freq0out, not User 4. It looks like there was once a launch control map in there that has been deleted without reshuffling of the fuel variable nesting. With that link in the chain gone, the fuel pathway was dead ended. Make sense?
Shiv
Old Mar 9, 2006 | 09:30 AM
Does the base xede guide have anything detailed in there on map nesting? that seems to be my only downfall.
Also before i was using the launch control map to set my rev limit to 7600 - is there another/better way of doing this?
