Signature Downpipe
Old Apr 10, 2006 | 08:12 AM
dridge11's Avatar
Signature Downpipe
It appears Vishnu only sells the downpipe in a set along with the HFC and test pipe. I already have the HFC and test pipe...so I'm just trying to find a signature downpipe for an otherwise stock 05.
Any suggestions? I would just get another brand, but then I'd have to figure out a way to work with the v-band clamp.
Old Apr 10, 2006 | 08:37 AM
donour's Avatar
Does your HFC have the fitting to mate up to the vishnu downpipe v-band clamp?
d
Old Apr 10, 2006 | 09:12 AM
dridge11's Avatar
d
Yes, it does.
Old Apr 10, 2006 | 09:49 AM
donour's Avatar
Originally Posted by dridge11
Yes, it does.
Ok then. Call them an ask if they will just sell you a downpipe. They probably will.
If not, then you can probably find a good, used one available in the for sale section. You have to be patient though.
d
Old Apr 13, 2006 | 07:16 AM
dridge11's Avatar
Alright, I found someone that will sell me the signature downpipe. It came off his 2003, and I have a 2005. He said he has some metal spacers that he needs to find for me. Are these metal spacers all that's needed to solve any issues fitting a 2005 vs a 2003?
Also, in the event that he cannot find them, are they available for sale thru Vishnu or elsewhere?
Old Apr 13, 2006 | 07:20 AM
dayf's Avatar
The spacers are probably just washers so that you clear the second lower arm bar. I'm not sure about clearing the active center diff though.
Old Apr 13, 2006 | 07:30 AM
dridge11's Avatar
Yeah, he just e-mailed me to clarify. He said the spacers are to lower the "cross bracing" in the front since the pipe is so large.
Guess I will e-mail someone at Vishnu and see if the center diff will pose a problem.
