Off throttle tuning?
Old Apr 18, 2006 | 01:19 PM
Jeff_Jeske's Avatar
Prior to the install of cams my car was very smooth when going from WOT to lift throttle/braking conditions. After installing cams whenever I get off the throttle my car feels like its loading up with fuel and it bucks a little bit before coasting down normally.
I primarily road race and this jerky feeling does upset the car enough to have me asking for help. What kind of tweaking do I need to do to ensure when I lift off the gas the car won't jerk me around.
Also if you feel this might be something other than tuning feel free to suggest a fix. For those about to suggest the DV, I've tried both my stocker and my JDM DV and the feeling is the same.
All I know is the jerking started the same day cams went in.
Help me out!
Old Apr 18, 2006 | 06:28 PM
RazorLab's Avatar
I had the same problem on the track. I've leaned out my low loads and it has helped.
Old Apr 18, 2006 | 07:03 PM
Jeff_Jeske's Avatar
Hmmmm.....I barely hit 60% load as it its.....what do you consider low load levels?
Old Apr 18, 2006 | 07:12 PM
RazorLab's Avatar
Well, since I'm not using the XEDE it will be a bit different. Figure out what load areas you are hitting at partial and trailing throttle and you can go from there.
You can see the tweaks I did here:
Old Apr 18, 2006 | 08:40 PM
jj_008's Avatar
60% is high on a stock turbo w/ the XEDE. Try adjusting the 30% or lower load cells.
