SMART XEDE harness?
SMART XEDE harness?
Shiv & Co.:
Did you guys ever make a SMART XEDE harness? I remember some mention of one last year. If so, can you supply one for the St. Louis dyno day?
l8r)
l8r)
in the pic, the grey connector at the bottom of the image is the deutch connector i wired into the xede harness. it has the three grounds (white, blue & green) the brown signal wire and the black calibration wire. the other side of the connector is wired to the wideband wires of the same color (i just cut about 3-4" off the wire ends on the wideband and used those wires to wire into the xede harness and the connector). the red wire is bare for firmware update for now. i also used 2 conductor deutch connectors for a remote status led and one for the map switch. i'll post some more pics this weekend after shiv tunes my car on sat. i made a panel behind the glove box for the calibration momentary switch, calibration led and map switch.
it really isn't plug and play as i had to wire it all up... i needed to be able to disconnect the wideband at the xede
