Xede - Configure Timing Signal dissappear
I am starting to not like this Xede V3.2 - I don't care about SMART, I like V2 better. However, now that the firmware is complete, there is no turning back.
My timing signal was set to Even4 for Mitsubishi, I reburn map to be sure it sticks, and BOOM, a week goes by then recheck maps, timing signal blank - have to reset it from none to Even 4..... What gives? Another bug? First it is "maps aren't the same", now losing timing signal? Do I even need the right timing signal or will blank work?
Can someone answer my boost question also - I don't use SMART, so do I zero out my SMART boost table or leave it populated? I control boost witha greddy profec and solenoid.
Of course you can go back. All you have to do is flash the v2 firmware, then load a v2 map.
d
Thanks for the answers. I still have anxiety about the timing signal being left blank - this is in the Configure Timing Signal option in the V3.2 menu. If I leave it blank and don't select the Even4 selection, does it effect performance? I guess I don't understand the relationship between the timing map, and the timing signal defined in the setup menu?
The timing signal is not left blank in the XEDE. The window you are looking at is just to upload a new timing signal. It will not display the timing signal that is currently configured in your XEDE. If the car runs, you have the right timing signal in there. It's as simple as that. But if you still, for some reason, want to see what timing signal is loaded into your XEDE, go to the diagnostic menu and click on XEDE information. It will tell you.
shiv
shiv
