Hot hot hot. XEDE overtemp protection
Originally Posted by Dustin@Vishnu
Try reloading the firmware and the maps, and see if that fixes your issue. If it does not, send it in so I can do the overtemp mod.
But it has SMART in the zipped file and my car does not have SMART. I want to make sure to use the correct firmware.
There are also two firmwares in the Xmap program.
one says
Xcode V3203 TEST ONLY_v31b8 M XEDE ONLY Single Retard. hex
and the other says:
Xcode V3203 TEST ONLY_v107b1 pre8.hex
I am not sure which one to use. Please point me in the right direction
Well my problem has since gone away when I loaded up a new map -- which makes little sense to me. The old map and the new map are the exact same size. odd...
I'm still a bit worried this problem will come back when it reaches higher temps this coming weekend -- is it possible Dustin that you can show us what you are soldering?
