Xede rpm signal question
Old Jun 27, 2006 | 03:01 PM
nj1266's Avatar
I want to know which pin is the Xede rpm signal? I want to tap into the wire and get the signal to my LM-1 and log the rpm that way. Currently I am using the inductive clamp to pick the rpm signal.
I looked in the Xmap pinout and I found the following possible wires to tap:
1. Black B plug crank-in orange/white wire.
2. Grey A plug crank-in white/yellow wire.
Is it one of these? or is it neither?
Thanks
Old Jun 27, 2006 | 07:28 PM
Jorge T's Avatar
Neither iirc xede replicates rpm from the CAS signal. I tapped the ECU tach signal wire, pin 58.
