Xede and Upgraded WG Actuator
I'm running the standard non smart 93 octane v390 map. I recently bought a 10.5 hotside and a o2 housing. I will be doing a manifold also. I'm also interested in upgrading the wastegate actuator while I have it all apart. My question is, will a higher pressure actuator mess up the off the shelf map in any way (I will be using the 05 v390 93 oct map with the 10.5 hotside)? I dont think it will because the xede will see the higher pressure as higher load and compensate. Well thats what I think anyway. Anyone know the definite answer? Also, can anyone make a good recommendation for a spring rate for an upgraded actuator?
The higher pressure actuator will require you to drop the numbers in your boost table. Instead of the usual 90-100%, start off with 0% everywhere and go from there to achieve your desired boost. If you don't modify your boost table like this, your boost levels will be astronomically high!
-shiv
-shiv
awesome. thanks shiv. i did find someone running a forge motorsport wg actuator with a 10.5 hotside and the xede. said he had to cut the boost in about half. it was buried in a thread about installing one. any recommendations for one?
-shiv
-shiv
I put 2 restrictors in my stock line. 50-60% for 21 psi
