Getting ready!! AMS 2.3/HKS280's/Methanol Inj! Have Q's
I got the injectors, "scaled" the Flashed ECU, have the Xede box hooked up, and now I am ready (tomorrow) to fire it up. How do I drive it around without blowing it up, (From lack of current tune). Is there any Maps/tables I need to "tweak"? can someone shed some light on this? I will get my tune soon, but MAN!!! I want to drive the car. Should I drive with the stock/scaled ECU? Or do I mess with the other tables in the XEDE???? Any help is GREATLY appreciated.
I am not taking the car to the track, until tuned, but I would like to do some 1/2 - 3/4 boost runs. I have the methanol OFF and not in use until I tune it, unless someone has a "generic" meth map. I have V390, NO SMART! thanks again.
P.S. GREAT THANKS to Dustin/Shiv for getting the box out and back to me in 1 DAY!!! My hats off to you guys!!!
![Pimp](https://www.evolutionm.net/forums/images/smilies/pimpflash.gif)
![HeadBang](https://www.evolutionm.net/forums/images/smilies/headbang2.gif)
Can't you get an XEDE "stroker" map from someone like Smogrunner that'll get you running around until you get your own custom map? Till then keep the boost level way down and you should be fine as the ECU is compensating in closed loop. Monitor your AFR's and O2 voltages as well.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
