Could i zero out my timing table if.....
Old Aug 12, 2006 | 07:44 PM
jrsimon27's Avatar
could i zero out my timing table for the 100oct map if i use 109vpracingfuel??
Old Aug 12, 2006 | 07:56 PM
EvoTio's Avatar
My Stage 1 100 octane Xede timing map is zeroed out, but it was custom tuned by Shiv. You would have to moniter for knock to be sure it's done safely. I would believe that with VP 109 it would be safe as long as your fuel map is not too lean.
Old Aug 12, 2006 | 07:59 PM
jrsimon27's Avatar
what afrs you i use with the 100oct map?? thanks
Old Aug 12, 2006 | 08:09 PM
EvoTio's Avatar
My AFR's are about 12.5:1 on my 100 octane map.
Old Aug 12, 2006 | 08:45 PM
jrsimon27's Avatar
thanks i will try it out! also i see that you were at 12.5 my car on a 3erd gear pull on 91oct had afrs fluctuate 12.0-12.5
Old Aug 15, 2006 | 06:59 AM
nj1266's Avatar
Is that a drag racing set-up or a road course set-up? Did you ever monitor your EGTs with this map on a road course?
Old Aug 15, 2006 | 09:13 AM
EvoTio's Avatar
Haven't been to a road course, I drag race my Evo on occasion.
