XEDE and Meth
Old Sep 25, 2006 | 01:38 PM
HolyShiznit's Avatar
XEDE and Meth
Anyone know what methanol kit tends to work the best with the XEDE? I am searching around and just want to make sure that tuning won't be super hard.
Old Sep 25, 2006 | 02:06 PM
Dustin@Vishnu's Avatar
Ams.
Old Sep 25, 2006 | 02:09 PM
Cajun Power's Avatar
Ams!!! ! !! ! ! ! ! ! ! ! ! !! ! !
Run a search for Xede + Methanol and this thread should show up...
https://www.evolutionm.net/forums/sh...ht=cajun+tasty
Those are the dyno results on an Xede with AMS Meth at 100% meth.
Old Sep 25, 2006 | 03:15 PM
smokedmustang's Avatar
Ams!!!! It sprays HARD, and is built to get the job DONE!!
Old Sep 25, 2006 | 04:00 PM
WhiteEvo05's Avatar
Let's see AMS use that one on their website...
Old Sep 25, 2006 | 04:51 PM
Old Sep 25, 2006 | 05:40 PM
Sounds like a plan then. I just wish that I could get my XEDE upgraded so I could hold two full maps. Right now I have NLTS and Launch Control on both my pump and race gas maps and I have to burn the eprom when I want to switch it. (Only done this once).
Btw: This whole set-up is an AMS 3071R kit.
Old Sep 25, 2006 | 06:40 PM
I have LC and NLTS on my 93+Meth map and SMART 93 on the other. You don't need SMART on you meth map and the Xede can hold both.
Old Sep 25, 2006 | 10:42 PM
So drop the SMART tables and I can fit them both on the XEDE? Sweet. Umm, Cajun, once again could you explain how I do this.
Old Sep 27, 2006 | 06:06 AM
On your pump gas map use the smart template. On the pump+meth map use the NON smart enabled template. Then you will need to add a meth table and adjust the logic flow to include the meth map into the flow (input/output of tables).
Old Oct 2, 2006 | 06:33 PM
So in terms of timing, if you have your timing map zeroed out (no retard), then with methanol would it be advantageous to ADD more timing? I have always heard/read/seen people add lots of timing when using methanol. Should I just add +1 to +2 degrees of timing from 5k+ on my methanol tune?
Old Oct 4, 2006 | 10:06 AM
Bueller yo!
Old Oct 4, 2006 | 01:48 PM
A418t81's Avatar
Any word on the Xede box to directly control the pump?
Old Oct 5, 2006 | 03:04 PM
No, mine is not that agressive. Do a search in the Vishnu section for Houston Dyno and get the results from our dyno day and look at my map. It is 0's for the most part and -'s at high rpms.
Old Oct 5, 2006 | 03:05 PM
Not that I have seen. I think the conditional logic is supposed to take over that role.
