Dynoday @ T-Trix April '07
Thanks Igor
Note: If you're coming up from US1 South, it's a little funky; you have to turn right, drive a few hundred yards, make a couple of rights (you'll drive over US1), stay to the left, and make a left on Woodbridge, and they're right there on the left
question, will Shiv be able to reload the software on the Xede to run the whole SMART system or this has to be done before the tune?
I prefer him to do it since I had some problems with my old Xede that it would not do that properly and they had to send me a new one, I do't want to go through this problem again and not be able to start the car.
Craig
All set and ready
272 Cams are in, Fuel Pump is in, Exhaust is on, SMART is installed. All ready to go.
I don't really care so much about max numbers, I just want a consistent tune, a smooth idle and.......around 330 whp (ok ok, so I lied, I do want SOME power....
I think you should make around 340-350.
Hi Calvin I sent you a PM and also called. Left the information with David about an hour ago. I have not checked the board in a couple of days that why I had not responded. Sorry about that. I will be there tomorrow. Can't wait.
I called and left a message too.. .... ....... .......
