Commonly Used XEDE Pins
Old Feb 6, 2007 | 06:17 PM
EvilBlueEvo8's Avatar
I thought of doing this a while ago when I went on a search for a certain pin number/color. Then when I had to do it again today and had to read through a bunch of different threads to find what I want, I finally did it. Here is a list of the most commonly used XEDE pins. I just wanted to put them all in one place. And before someone says, "its on the XMAP help", they don't list them with what should connect to the pin. So I think this may be more helpful to some. If anyone wants to add something, go ahead. Otherwise, enjoy!
AN1 Input – Grey Connector – Pin 10 connects to Wideband 0-5v output
AN0 Input – Grey Connector – Pin 9 connects to Knockbuffer 0-5v output
AN1 Ouput – Grey Connector – Pin 3 connects to Alky Controller 0-5v input
Drive 1 Input – Black Connector – Pin 1 connects to Clutch Wire for NLS/LC
Boot Mode Input – Black Connector – Pin 9 connects to 12V only for Firmware Update
Ext LED 1 Output – Black Connector – Pin 11 connects to LED
Ext LED 2 Output – Black Connector – Pin 12 connects to LED
Red and Red/Black wire pair – Pigtail from XEDE harness – Connects to Map Switch**
**Off: Bank zero; On: Bank one
Oh and one more thing. If you are adding pins to blank spots, you're gonna need connectors. The Xede's connector's are the DTM series. There are several possible contacts that can be employed but the best one is P/N 0462-201-2031 (socket, gold, 18-24 AWG.) You can just solder to the contact and forget about crimping them. (Unless for some reason you have a crimping tool for mil-spec connector contacts. For reference it is ~$200!)
You can get those here (or from Vishnu of course):
http://www.deutschconnector.com/cgi-...M_Sealing_Plug
Old Feb 6, 2007 | 07:32 PM
Jorge T's Avatar
Cool!
Old Feb 6, 2007 | 07:54 PM
oh and a note about the led, you need a 2 way and you'll need to test to make sure it lights the same way as the one on the xede. if it doesn't, switch the connections and it should be the same.
