Help with a MAP
Old Mar 13, 2007 | 03:04 PM
EVIL_EV0's Avatar
Question Help with a MAP
My car was a full stage 1 plus EVO with the appropriate map.
But because I have a preoccupation with wasting time and money on go-fast parts I decided to combat my issue by returning my car to nearly stock!
In all honesty it worked. I no longer spend hours on EVO-M looking for the next best turbo upgrade costing thousands of dollars and I'm no longer tempted to race every fast car I see on the street. Other than no longer being the fastest import in town I okay with my plan.
Here's the problem..... over winter I pulled off and sold 99% of my mods. I now have a virtually stock evo with xede, cams, cam gears, testpipe, and a whinebro fuel pump. (yes stock exhaust less the 2.5" home made testpipe)
I have no way to detect knock and no standard map to download. I do know how to tweak my timing and fuel but I'm not sure what is "SAFE" to pull out.
My questions are:
1. How much boost SHOULD be safe?
2. How much fuel can I yank out?
3. How much timing do I need to pull because of #2?
I know I'll get a speach about how I really need a tune and yadda yadda yadda but there should be a SUGGESTED tuen that I can try. I know there is a risk but its not much different than the danger associated with the standard issue vishnu maps.
Help!
Old Mar 13, 2007 | 04:48 PM
Noize's Avatar
EvoM Administrator
1. ~20psi is a good starting point
2/3. Every car is different. Try an old base stage 1+ 91 octane map until you can get on a dyno. That should be totally safe, but leave the boost around 20-21 until you can see for sure.
Old Mar 13, 2007 | 05:47 PM
jrsimon27's Avatar
buy evoscan and get the taxtric cable and buy a wideband which you can log with evoscan like aem or innovative and then youll be set
Old Mar 16, 2007 | 02:19 PM
EVIL_EV0's Avatar
I've been reviewing maps and it seems 20 psi -- pulling 8% fuel and 1* of timing is the tune I should aim for.
I've plugged those number in and the car still pulls very good considering the lack of 3" exhaust. I test drove an EVO9 today and my lightly modded 03 would lay waste to the stock 9. But that is apples to oranges I guess.
Thanks for the info.
On a side note....... I'm planning on getting the ECUscan and WB. I simply haven't decided on a WB yet.
