Disabling Xede Boost W/O Removing Xede
Old Apr 4, 2007 | 12:23 AM
nj1266's Avatar
Does anyone know how I can disable the Xede boost control function w/o removing the Xede?
I want to test some ECU boost control maps and I want to disable the Xede boost control.
Thanks
Old Apr 4, 2007 | 04:17 AM
SuperHatch's Avatar
Thanks
Just return the relocated blue (I think) wire back to the ECU socket, it's that simple. Make sure you tape off the wire coming off of the Xede (green?) to avoid it shorting out on something.
- Stephen
Old Apr 4, 2007 | 08:15 AM
nj1266's Avatar
- Stephen
I did some research after I posted and it seems that removing the boost wire (light green) from the Xede harness and plugging it back inot the ECU harness is the only way to do it.
I was hoping that there would be a way to do it with the software. Oh, well.
Old Apr 4, 2007 | 04:37 PM
Kronik's Avatar
Could you zero out the boost table??
Old Apr 4, 2007 | 07:19 PM
SuperHatch's Avatar
No, that would not return the control t the ECU. The Xede does not intercept the boost signal, it simulates it through the wire switch. The Xede sends a fake signal to the ECU to make it happy and not trip a CEL for the BCS being disconnected and then controls the BCS directly.
Old Apr 5, 2007 | 07:00 AM
Kronik's Avatar
Ahh, thanks for the info
Old Apr 11, 2007 | 09:08 AM
DaWorstPlaya's Avatar
Disconnect the boost control wire as everyone has suggested ... it's the one seperate from the harness. Superhatch is right, the Xede doesn't intercept boost it directly controls it ... setting it to 0 would probably give you 7psi peek boost.
Old Apr 11, 2007 | 08:13 PM
nj1266's Avatar
I removed the xede entirely. I now have the ECU controlling everything, including boost. Ecuflash solved it all for me.
My gf tried the xede on as a neckless when I told her how much I paid for it in March of last year, but it did not look too good
I am still amazed about how fast Ecuflash made almost every other tuning hardware obsolete for the Evo in a span of one year.
