How much HP can you expect with a base map....
Old Jun 14, 2007 | 04:18 PM
CrackerJackToy's Avatar
...on a bone stock car? Or am I just best off going with a flash?
I used to have an Xede for the past 9 months on my turbo Miata (which I just traded in on the EVO, so I just sold that Xede for $850)... obviously here, xedes are cheap for evos. LMK if its worth the money.
Old Jun 15, 2007 | 09:24 AM
donour's Avatar
Actually it would be best to have BOTH. Buy the tractrix cable and you can reflash the stock ecu yourself. I like the Xede because you can switch between multiple maps quickly and it provides a finer degree of control. There's a number of Xedes in the for sale section in the sub-$200 range. Pick one of those up then order the tractrix cable. Then you'll be all set for practically any modifications you want to do.
20 hp is a pretty safe estimate on a stock car. With a full exhaust, double that figure.
d
Old Jun 15, 2007 | 02:39 PM
So 20whp with just the xede or 20 whp with xede & the tractix cable? I thought you got that alone with just the flash.
Old Jun 15, 2007 | 06:32 PM
donour's Avatar
20 either way. You can expect about 20 more hp from a properly tuned stock evo. Some people get more, hardly any get less. The Xede really doesn't give you a 'better' tune, but it does provide other convenient features. For example, vishnu provides maps for standard mod configurations.
There are a couple of things that the Xede cannot do. You can't change the rev limit with the Xede, nor can you remove the boost limit or change idle settings.
d
