Help!!!
So I just got my car back from having a clutch installed and noticed that something didn't feel right. I went WOT and was only pushing 12 psi of boost. I've had the v330 map loaded for months now and this is the first time I've seen this happen. I figured it was because the battery was disconnected for long enough to reset it, seemed strange with the XEDE but thought it possible. I just tried reloading the map and got an error message as soon as I started to load the map, it just wouldn't burn in. Has anyone had this issue?!
Sounds like the lower pill fell out of your vacuum hose going to the wastegate, when they removed it for the clutch install. Its no biggy, you can go to your dealership and pick up a new set of boost hoses.
