Xede Install
Just finished the Xede Install. The car scoots 2 times faster. There are a couple of install problems with instructions.
On my car, the socket size is 10mm not 12mm (to remove the bolts).
There are only 2 bolts which hold the air filter.
The harness description is in reverse order (the largest clip is on the right not left).
As a novice it took me about 30 min. to install. I had to go back and forth getting additional equipment and resolve the socket size issue. I also had to switch between a 5" extention and using the 10mm socket without. On a scale of 1 - 10 the install is a 1 in difficulty.
David
David
Thanks for the heads-up on those instruction mistakes. I'll get it taken care of asap. Glad to hear the install went easy!
I'll be posting up new beta maps next week. They are slightly more aggressive than the normal baselines and should provide even more scoot
Cheers,
Shiv
Cheers,
Shiv
ok i am having troubles removing the light green boost wire from the factory harnes....are there some tricks i am missing?
i popped up the white clip from the top of the harness...but i can't get the wire out of the harness.........help please
shiv
Cheers,
Shiv
Cheers,
Shiv
