XEDE diag light?
Old Nov 17, 2003 | 05:08 AM
Lacoste's Avatar
XEDE diag light?
Shiv/Vishnu guys,
I had my XEDE on the floor the other day, and I noticed that the light between the cables, which is normally a steady green, was flashing orange. It stayed that way until I stopped the car 30 minutes later; when I restarted about an hour later, it was a steady green again. What are the different states for this light, and is there some kind of users manual for the XEDE? I received mine via hand delivery, so if I'm missing any documentation, let me know how I can it
Thanks,
Lacoste
Old Nov 17, 2003 | 06:18 AM
limey's Avatar
I would check that the two red wires, used for switching maps, are not able to touch each other.....I can be corrected, but I think the orange flashing light means you have switched to the secondary memory in the xede by mistake....what boost pressure where you able to reach with the xede in this state?
Old Nov 17, 2003 | 08:46 AM
KK's Avatar
KK
EvoM Administrator
Actually, I think if it remained flashing then there may have been a connection issue. The Map switch should just blink and then go green once the map is loaded from what I know.
Is it staying green now?
Mark
Old Nov 17, 2003 | 12:14 PM
Lacoste's Avatar
Yeah, it's back to staying a steady green. I haven't lost any boost, and I'm not sure if there's anything loaded in the alternate map, because I haven't connected to the XEDE myself yet. I just got a serial cable today to do that, so I'll check what it looks like. The red cable to toggle the maps isn't connected to anything right now, I have it coiled up and taped off for the time being.
Lac
