Got my xede today
Old Nov 25, 2003 | 12:36 PM
Eric Lyublinsky's Avatar
Originally posted by 2fast2Furious
Okay I got it now! Remove the light green wire, then install the light blue wire from the xede. Next take the light green wire "the one off the stock computer" and put it together with the black wire "From the xede" And shrink wrap both of them together and they do not go into anything. What was screwing me is I though they all went together and into the harness lol.
Yep now enjoy!
Old Nov 25, 2003 | 04:53 PM
tom@kartboy's Avatar
that dosent sound right
the BLACK wire will go to the ground the blue wire will go from the pin you took out and the other end will be pushed into the spot where you took the pin out. think of a bypass
tom
Old Nov 25, 2003 | 05:07 PM
MP5's Avatar
MP5
In Timeout
tom
I think its right I have seen xede harnesses with a black solenoid wire
Old Nov 25, 2003 | 07:36 PM
2fast2Furious's Avatar
In Timeout
Well it looks like I will have to drive my other car tomorrow, The directions for the xede suck, and I took out the wrong wire because there are 2 light green wires. I think Shiv needs to re-write these directions because as of now they are missing 1/2 the steps and we need to have a better way to get the damn pins out. what's the trick?
Old Nov 25, 2003 | 08:56 PM
hmm i didnt have a problem at all pulling the wire
its on the main plug. third wire in from the right top looking at the wires side.
took about 5 min to get that all swapped over for me. you need to get the small screwdriver like it says on the instructions. then a little finess and the wire pops right out.
you can drive the car without the boost controler hooked up. it just wont have the same pop( hmm bad choice of words) that it will have with the XEDE controlling the boost. the boost curve will stay stock 19.5 going down to 16ish at redline
tom
Old Nov 25, 2003 | 10:03 PM
In Timeout
I also broke off the screwdrive head in the harness, I need to stick to what I am good at not this car mod install **** lol. Best case my wife fixes it tomorrow, worst case I get it towed and let them fix it. No biggie.
Old Nov 26, 2003 | 12:08 PM
evo1's Avatar
Dumbass!
Old Nov 26, 2003 | 12:23 PM
Originally posted by evo1
Dumbass!
Ya well Chris is driving your car right now. I was on the phone with him, helping him load the map into Xede.....
I hope he is a good driver or else I'll be calling you a DUMBASS!!!
Old Nov 26, 2003 | 02:38 PM
In Timeout
Got my cams from Vishnu today, you can bet your sweet *** I am not even going to open the box. Well at least I did not have to drive the EVO to the shop, the tow truck got it there for me.
Old Nov 28, 2003 | 01:06 PM
evo1's Avatar
Much better choice dude - good for u!
Old Nov 28, 2003 | 01:29 PM
In Timeout
lol thanks, should have everything done in the next 2 weeks. Will post a dyno once all is done.
Old Dec 2, 2003 | 01:14 PM
evo3323232's Avatar
In Timeout
Okay here is a update on my xede, My name has changed and you can thank the mods for that. Anyway, After I got the xede installed the car would not hold a cold idle at all, I mean it would stall without the gas and not even try to catch it. All I did was turn the idle screw about 1.5 times and it went from no idle at all I mean it would not ever start without having the gas pushed, now it starts fine without the gas and hangs around 850rpms. People with the xede problems may want to mess with the idle screw. I will see if I can get a pick of where it is tonight. Hope this helps.
