Xede boost in Intercept mode
Old Nov 28, 2003 | 07:50 AM
Jev3gs's Avatar
Anyone with an Xede, please help. I must installed Stage 0 plus downpipe map on my Xede. I live in Chicago so its pretty cold here. Well I hit boost cust last night and I want to drop the boost 1lb. The problem is though I don't know how many lbs of boost I am running at 100%. Is 100% like 19lbs or is it 21lbs?
In 5th gear at like 65mph I hit like 22-21 lbs of boost. I want to
drop that to about 20.5 to 20lbs. I just don't know what % to put it at. Anyone know?
Thanks,
Jeff
Old Nov 28, 2003 | 07:57 AM
MP5's Avatar
MP5
In Timeout
drop a half percent ot just highlight the on boost zones (anything above the bottom three rows) And presss the (,) key a couple times
Old Nov 28, 2003 | 08:18 AM
Jev3gs's Avatar
So if it is at 100% now, you are saying to change it to 99.5%?
Old Nov 28, 2003 | 09:06 AM
MP5's Avatar
MP5
In Timeout
Not really thats the % on/off for the FBC not necessarily a psi assignment. so you will have to check the psi drop a % change will yeild- I bet it cant be correlated to linear. I would just hit the (,) key 2 times at a time till you have a good safe peak boost
Old Nov 28, 2003 | 09:07 AM
MP5's Avatar
MP5
In Timeout
Um you could also just take out that K&N and I bet that will 0 your MAF and be the correct psi setting
Old Nov 28, 2003 | 09:28 AM
Jev3gs's Avatar
I might try that. I never really noticed a difference a difference at all with the drop in. I was hoping to atleast get better gas mileage, which never happened
