Controlling Water Spray with Xede
Old Dec 6, 2003 | 10:08 PM
Smogrunner's Avatar
Hey fellow Vishnuites,
I'm playing with my new Xede and was wondering if the Water Spray Setting feature really works? If yes what are the best settings for it?
By the way, I still can't get the dumb grin off my face. It really rocks.
Old Dec 9, 2003 | 06:02 AM
Smogrunner's Avatar
bump, cause this is a good question
Old Dec 9, 2003 | 08:02 PM
Angel Of Mercy's Avatar
i think for this you need to look at a dyno run with boost and intake temperature.... from the curves you should be able to tell when the intake temperature begins to run hot and thus you should be able to run the spray from those boost pressures onwards.. however, you want to take caution because continous high speed runs can cause your spray to run continously and exhaust your water supply... and if they happens and you still run high unaware, you will burn out your spray motor....
Old Dec 11, 2003 | 04:15 PM
limey's Avatar
I thought that feature controlled water injection... not the water spray?
Old Dec 30, 2003 | 03:40 PM
mapmaker50's Avatar
I thought you will more likely to get any answer on the threads below - just a few thread apart.
https://www.evolutionm.net/forums/sh...threadid=55246
There are one or two wi/ws (water spray) Xede topics there that may have answered you questions.
