Broken rear differential
Old Jan 19, 2004 | 10:51 AM
USP45's Avatar
You now have a spool!
Old Jan 20, 2004 | 05:14 PM
johnnyevo's Avatar
bummer man! Let us know how the new set up works out! And then get back to the track to "try it out"
You know its eating you up inside shiv!
john
Old Jan 20, 2004 | 06:05 PM
shiv@vishnu's Avatar
Yeah!! Turns out something is wrong with the front differential as well
ugh...shiv
Old Jan 20, 2004 | 06:23 PM
USP45's Avatar
Hmm.......that is a lot of destroyed parts. Whats up with the front diff? I am starting to wonder if 430-470 whp is not such a good idea on the stock parts? I know that you have to pay to play, but with all of the new turbo kits coming out this could be the tip of the iceberg so to say. We may be in for a rash of broken front and rear diffs along with tranfer cases, tranny's, and center diffs. I guess time will tell. This could become a constant chase of reinforcing one thing just to go on to the next.
Old Jan 20, 2004 | 06:24 PM
RonV's Avatar
Shiv,
What are you gonna do as far as the front diff is concerned?
Go with a stock replacement or are there upgrades for the USDM EVO???
As far as I know no one makes any upgrades for the front diff of our Yankee cars.....unless you can pull some strings and get an RS LSD some how.
Also, I would like to know if you could post pics of the front diff install? It would be interesting to see how that flywheel looks after all of the dyno time.
Good luck!!
Ron
Old Jan 20, 2004 | 06:36 PM
gtr's Avatar
gtr
Sorry to hear that. I can't believe the front diff is bad. Are you going to check the center diff? Stuff like this makes me wanna get a skyline, but anyways good luck on getting your car up and running soon.
Old Jan 20, 2004 | 06:43 PM
n00dle's Avatar
You've ruled out all of those hours on the dyno as the dyno being the catalyst to the failures? Failures seem excesive from just a couple of runs down a strip. Granted it has more HP, etc., but reports of failures have been small.
Old Jan 20, 2004 | 09:30 PM
The dyno puts not unusual stress on any of the differentials since there is no wheelspeed differential between any of the wheels. Nor is there any shock loading of any sort.
All the noises/clunks/binding occurred after the trip to the drag strip so I hold those 4 wheel burn outs/axle hopping the cause of the failures. And not to worry, the car is still up and running. Clunks and all
Cheers,
shiv
PS. I should also mention that I run R-compound race tires (255-40/17) on a daily basis so they tend to make life harder on the drivetrain during launches as well.
Old Jan 20, 2004 | 10:38 PM
Noize's Avatar
EvoM Administrator
Yikes!! That puts me a little bit more at ease about my drivetrain with upcoming mods. R compound tires + VHT = super glue. Super glue + AWD = kaboom.
I still think you've scared me off drag racing for awhile, Shiv. I have two quarter mile passes ever on this car, and they might be the only two I do... Unless my WRX/SRT-4 friends get too fast and uppity... Must... resist... temptation.
Old Jan 20, 2004 | 11:11 PM
ez76's Avatar
Shiv, you may went to check out the current Quaife group buy thread:
https://www.evolutionm.net/forums/sh...ghlight=quaife
Old Jan 21, 2004 | 08:15 PM
johnnyevo's Avatar
oh man! Keep us posted! What makes you think the front is toast? Same thing cornering? Thats a bummer man! I would think that the rear would take most of the grunt with the weight transfer and all. Maybe it has something to do with the lubricants you used? Let us know! I want to end up with a stage two, that is, if it doesnt require beefing up the whole drivetrain!
John
Old Jan 27, 2004 | 05:37 PM
RonV's Avatar
Hey Shivarino,
Is this fixed yet?
Old Jan 27, 2004 | 05:52 PM
Still working on it right now. We had to steal parts of another EVO since some replacement differential parts (bearings, oil seals, etcl,.) aren't available at the dealer
Shiv
Old Jan 27, 2004 | 06:08 PM
RonV's Avatar
That sucks in a major way! Did you guys end up doing both diffs?
Old Jan 27, 2004 | 07:14 PM
ez76's Avatar
hang in there guys!
