SE Vishnu Dyno Day! May 15th GA
Old Apr 2, 2004 | 11:02 AM
  #181
Noize's Avatar
EvoM Administrator
Originally posted by skicracka
Well then lets fix it!!!! Don't you know who I am!?!?
You're Darby JAYYYMMMEZZZ, bish!
You need Cooter, b/c he has Delta Dash.
Race gas should procure 25-30HP in your rig.
Old Apr 2, 2004 | 11:49 AM
  #182
cooter's Avatar
Check your PM's skibum.
Old Apr 2, 2004 | 11:54 AM
  #183
Dracon's Avatar
Doesn't everyone need cooter?
Old Apr 2, 2004 | 11:55 AM
  #184
skicracka's Avatar
Back at ya
Old Apr 2, 2004 | 12:57 PM
  #185
GRoceryTurbo's Avatar
Hey Sethro... how many ponies do you think I can aquire running a race gas map?
around 20ish.
Old Apr 2, 2004 | 01:08 PM
  #186
Noize's Avatar
EvoM Administrator
Updated 02 April 2:35pm
Note that per Shiv's request, start times have been adjusted an hour (8am is 5am his time, yuck!) Therefore, we'll either be starting at 9:00 or 9:30 am. !!!Please understand that your actual times are approximations, as some cars will take longer than others!!!
Saturday 15 May starting at ~8:00-8:30am
01 (9:00) Dude = Xedeflash custom tune on stage 1+ 93/100
02 (10:00) markluuv = stage 1+custom tune
03 (11:00) Nathaniel Martin = (WRX) /vf22 ECUtek custom tune
04 (12:00) Ryanmcd= Stage 1+ Custom tune
05 (1:00) MYEVOVIII = **Upgraded to XFlash custom tune
Shiv takes a break and we'll run two of the power pull guys.
06 Snoop = Dyno pull/baseline
07 TreyS = Dyno pull/baseline (STi)
Shiv stops drinking Pina Coladas and hitting on all the local Southern Belles so he can get back on the dyno.
08 (3:00) rallyred= Stage 1(or 1+ ?) custom tune, XEDEFlash.
09 (4:00) Event-Horizon= Custom tuned XEDE (FIRST tuning car back on the dyno after Snoop and TreyS' power pulls)
10 (5:00) Toddevo8 = XEDEflash; custom tuning
11 (6:00) Skicracka/James = ECUtek secondary location RACE GAS map
12 (7:00) SilverEVO8 = Dyno Pull/baseline AEM EMS **Call Vishnu**
----END of Saturday tuning----
Sunday 16 May
01 (9:00) Andrew/Limey= XEDEflash+ custom tune
02 (10:00) is300= Xflash custom tune
03 (11:00) John/GRocery Turbo = ECUtek custom tune (WRX)
04 (12:00) Seth/Noize = Race gas stage 1 custom tune
Lunch break?
05 (1:00) Paul Hignutt = Xflash Stage 1 custom tune
06 (2:00) Jose Esc**** =Custom tune on Xflash
07 (3:00) Mike Killac*** = ECUtek reflash from UTEC 2.5l (WRX)
Old Apr 3, 2004 | 12:02 AM
  #187
Dracon's Avatar
BTW - who was MP5 on the Dallas trip? I can figure out everyone but him...
Old Apr 3, 2004 | 06:17 AM
  #188
Noize's Avatar
EvoM Administrator
Its David. The guy that set up the whole thing that Cooter and I roomed with right next door to you, ya crazy freak!
Old Apr 3, 2004 | 11:34 PM
  #189
Dracon's Avatar
ahhh, thanks.
oh, and Darby James, after I put my turbo back exhaust on, I get the same boost problem you have at WOT in 4th and 5th... but I didn't with the same flash on the stock one, so let me know when you're going to meet up with cooter and I'll go too...
Old Apr 4, 2004 | 07:46 AM
  #190
snoop's Avatar
A lot of cars to DYNO
Old Apr 4, 2004 | 09:30 AM
  #191
cooter's Avatar
Originally posted by Dracon
ahhh, thanks.
He shoulda called me yesterday, I was in Murfreesboro most of the afternoon/evening. *gobble gobble* We can meet up next weekend or one night this week at Seth's house.
Old Apr 4, 2004 | 01:21 PM
  #192
skicracka's Avatar
Hey guys. Sorry about that Cooter.. I wanted to hook up with you this weekend. Can we meet this week sometime like you had mentioned? Just let me know what nights work for you and Nathaniel and I can hook up with you. Is it hard to use the delta dash to change the wastegate duty cycles?
Old Apr 4, 2004 | 02:16 PM
  #193
Noize's Avatar
EvoM Administrator
It won't take longer than a couple of minutes. But Cooter (Chris) has thought of a problem with you getting a race gas map on the ECUtek, as the two different switchable maps might not allow enough customization (variance from one another) to accomodate the changes. If that's the case, you definitely need to keep your 93 octane map.
According to Chris, the two maps cannot have big changes, and the only real differences they can have are boost values. This is undoubtedly a Shiv question to see if there is any type of work around.
Old Apr 4, 2004 | 02:21 PM
  #194
shiv@vishnu's Avatar
Yep, the two maps in the WRX reflash can only differ in boost mapping. Fuel and spark stay the same. To truly make a race gas map, you will need Delta Dash to take advantage of the live tuning feature where you will be able to modify fuel, timing, knock learning, rev limits, boost, etc,. This is how I will tune. At the end, I will have you the values that you will need to put in (for optimal performance) yourself when the urge to run race gas should arise.
Cheers,
shiv
Old Apr 4, 2004 | 02:39 PM
  #195
cooter's Avatar
Tuesday or Thursday would work good for me. As long as Seth is ok with us meeting at his place on those nights, I think we'd be green
