Omori Gauge Question...
Do the Omori gauges you sell come with an adjustable back-light, or are they always the same color? I've seen pics of a few of them which were fully color adjustible, just wanted to see if yours are the same.
Thanks...
Thanks...
To the team @ Vishnu:
Which Omori gauges do you have in 52mm size? Aaron from Flatiron Imports in CO is placing my order with you and said that you do not have a Fuel Pressure Gauge in the 52mm size, so I'm trying to see what other type I can substitute in its stead (will be combined with Boost and Oil Pressure). AFAIK I won't need an EGT, since I will be installing a wide-band O2 sensor...
Lastly, regarding the color adjustments ... is that via a separate control box, and if so, is that included if I order a set of 3 gauges.
Thanks
Thanks
