XEDE on a RS??
Old May 26, 2004 | 08:25 PM
EVO8speed's Avatar
XEDE on a RS??
Does the XEDE work on a RS since the part numbers are diffrent for the ECU? Have you tested it on a RS yet? And when will the XEDE Flash follow for the rs? Thanks
Old May 26, 2004 | 08:28 PM
shiv@vishnu's Avatar
Yes, yes and yes
Shiv
Old May 26, 2004 | 08:52 PM
EVO8speed's Avatar
THanks, Mark(KK) and I are going to try it out on mine this weekend if all goes well. When will the xede flash be available for the RS or is there no diffrence between the RS ecu and the GSR ecu, which would make the current xede flash compatable? Is there a diffrence in the ECU since the rs has no ABS or Electronic brake distrubution, when compared to the other ecu?
Old May 27, 2004 | 05:24 AM
Noize's Avatar
EvoM Administrator
Sorry to go a bit off topic, but I think it is very cool that you have an RS; I haven't had the pleasure of seeing one yet. How do you like that front diff?
Old May 27, 2004 | 05:37 AM
EVO8speed's Avatar
If you live in the D.C. area you can come over and see it but it looks the same, besides the cheap interior bits. I have not pushed the car yet so i have no idea how its going to feel at the edge. but i'll let you know when i do. Thanks
