best map for test pipe
Old Jun 24, 2004 | 05:08 PM
smackmatic's Avatar
If I wanted to use a test pipe on a subzero car which map would be better, the subzero map or the 0 map? I didnt see anything on the vishnu website about this.
Thanks for any replies
Old Jun 25, 2004 | 05:59 AM
Eric Lyublinsky's Avatar
I have a 0 with cat less map if you need it? Email me and I can email you back the map this weekend. But I think you can run 0 with a cat delete.
Eric
Old Jun 25, 2004 | 06:09 AM
meanmud's Avatar
Mmm,
I think your original map is the right choice
Old Jun 25, 2004 | 08:24 AM
YEVOVIII's Avatar
Eric
Could u please send me your Stage 1 catless map? Please? lockdesk@overlandwholesale.com
Thanks
Tony
Old Jun 25, 2004 | 08:36 AM
Thanks
Tony
Tony do you have cam gears. Because I don't have a catless cam gear map.
Old Jun 25, 2004 | 10:13 AM
meanmud's Avatar
am I wrong
to think the original map is the right choice - whether or not you have a cat?
Old Jun 25, 2004 | 10:43 AM
It would be the safest route. The base maps are very conservative for good reason. Evos are so diffrent from on to the other when mapping.
With gears, Maps are usally much leaner then cars with out gears because the gears raise the knock resistants.
Being cat less also rasies the knock resistants and also alows the turbo to breath free witch mean you have to adjust the boost so it would not spike to much.
Eric
Old Jun 25, 2004 | 02:46 PM
smackmatic's Avatar
I always thought that less backpressure would actually lower boost, rather than cause a spike. Wouldnt removing the cat reduce backpressure?
Old Jun 26, 2004 | 05:16 AM
DystopiaMagnate's Avatar
Reducing backpressure means less work for the engine to pump exhaust through the turbine and out the exhaust system. Yes, removing the cat will remove its contribution to backpressure (though I'd like to see how much backpressure a properly-sized high-flow cat actually does contribute). Reducing backpressure should only improve the rate at which boost builds, as well as the peak power and torque figures. It shouldn't lower boost.
