Will the Xede override a dynoflash ecu reflash?
Old Jun 30, 2004 | 09:19 PM
denom's Avatar
Dumb question, but will the xede program override my dynoflash reflash?????? I just ordered one, and need to know asap. Thanks
Old Jun 30, 2004 | 09:30 PM
ez76's Avatar
It will work on top of your Dynoflash.
n00dle's Avatar
No it won't override it. Be cautious of what maps you load into the Xede and use, as it will compound the results. The Xede base maps were intended for use on a stock ECU without alterations to ignition, fuel, etc. Best to have the ECU flashed back to stock if you plan on using the base maps or have the Xede customed tuned with the current flash.
Old Jun 30, 2004 | 10:21 PM
denom's Avatar
Crap what can I do. Please somebody help me. Help me. Help me!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 30, 2004 | 10:27 PM
n00dle's Avatar
Send your ECU to Shiv. Let him know you've ordered the Xede and that your ECU has a flash on it.
Old Jun 30, 2004 | 10:29 PM
evo542's Avatar
it will work just fine since it's a piggyback controller (plug-n-play)
Old Jun 30, 2004 | 10:32 PM
n00dle's Avatar
It will work, but the tune will be off and depending on the level of the flash currently on there, the potential to wreck havoc increases. The base maps are built off factory parameters, not an aftermarket flash with manipulated parameters. IMHO, don't take that chance, do it right.
Old Jun 30, 2004 | 11:03 PM
shiv@vishnu's Avatar
Our baseline maps have been shown to work very well. Unless you want to generate your own custom map to be used with your Dynoflash, I'd recommend sending me your ECU to wipe clean of the Dynoflash. You will not miss it.
Shiv
Old Jul 1, 2004 | 02:39 AM
Ludikraut's Avatar
Better yet, send it to Shiv and have him clean it up and put on a XEDEflash.
l8r)
Old Jul 1, 2004 | 07:09 AM
jj_008's Avatar
Send the ECU back to Dynoflash for a refund and stock map reflash. Then when you get it back send it to Vishnu for the XEDEflash or just run it.
Old Jul 9, 2004 | 09:42 AM
Secret Chimp's Avatar
Keep in mind that Dynoflash does 'back to stock' flashes for free. All you would have to pay for is the fed ex costs.
SC~
Old Jul 9, 2004 | 11:49 AM
Dustin@Vishnu's Avatar
Doesnt AL have a money back deal if you dont like it?
Old Jul 9, 2004 | 12:43 PM
Quickshift's Avatar
He does but it is only after a certain period of time though. I think like 1 week maybe 2.
Old Jul 9, 2004 | 03:46 PM
nastea's Avatar
2 week money back guarentee
