Shiv: Fuel Pump Recommondation Needed
Old Jul 1, 2004 | 03:47 PM
freedom's Avatar
Shiv: Fuel Pump Recommendation Needed
Called the shop today and they suggested I get your input on the following....
With respect to a stage 1 Evo, 93 octane operating at 600 feet above sea level, do you recommend upgrading the fuel pump (e.g. Walbro 255)?
Last edited by freedom; Jul 1, 2004 at 04:10 PM. Reason: (Can't fix the typo in the title....)
Old Jul 1, 2004 | 04:04 PM
shiv@vishnu's Avatar
Yes, I'd recommend it. Might not be absolutely necessary until you add cams but doing it a bit earlier is a LOT better than doing it too late.
Shiv
Old Jul 2, 2004 | 09:21 AM
freedom's Avatar
One follow up question. Are aware of an alternative pump that makes less noise?
The rubber sleeve seems to make the Walbro assembly too large to fit into the Evo's in tank assembly. Are you guys using the sleeve on your installs?
Old Jul 2, 2004 | 09:26 AM
Eric Lyublinsky's Avatar
Just one statement. I have installed over 20 walbros in EVOs. They drop right in and fit perfectly. You might be doing somthing wrong or have the wrong pump.
Eric
Old Jul 2, 2004 | 09:37 AM
freedom's Avatar
No question w/o the rubber sleeve. With the sleeve the diameter of the pump + sleeve is too large for the tube that the pump resides in. Or am I missing something here?
Maybe there is a thin rubber sleeve that I don't have. Maybe cut it down to fit. Or something....
Old Jul 2, 2004 | 09:38 AM
I think Walbo does offer an optional rubbers sleeve to quiet its operation a bit. I can see why it wouldn't fit into the holder when equipped with it. There are other pump options from Denso that may be quieter. But my testing with them is pretty minimal.
Shiv
Old Jul 2, 2004 | 09:40 AM
jj_008's Avatar
The Sleeve is not needed. The only thing needed is the pump itself. My Walboro is absolutely silent.
Old Jul 2, 2004 | 12:43 PM
freedom's Avatar
I wish I could say the same for the unit I have in hand.
It isn't clear why some people say that their pump cannot be heard. The few vendors / installers I have talked to agreed that out of the tank all of the units sound the same. There is only one way to install the pump, hence this shouldn't be the difference.
It is notable that when the pump runs without a load it makes much less noise. As the pressure in the line builds, so does the pump's noise output. The large difference in the noise output between unloaded and loaded is very dramatic!
This said, I'm at a loss on this one. I have thought about picking up a second pump in the hope of finding something different, but I expect that this is just a waste of money.
Old Jul 2, 2004 | 12:46 PM
freedom's Avatar
Further to the last post....
I picked up a PE210 but it was received the outlet nipple broken off. The PE210 is a Denso look alike from a company that on paper doesn't appear to have anything to do with Denso. Maybe they purchased the rights to the design. If not they ripped it off.
The older PE210's appear to have been sourced from Denso, but I have been unable to get a Denso part number for their higher output pumps that are form factor compatible with the Evo.
Shiv
Old Jul 2, 2004 | 01:16 PM
jj_008's Avatar
I have heard a sound clip of a loud Walboro and it was really loud. What scares me the most is the only thing in those things is an electric motor with some gears. That sound is the electric motor bearings in my opinion. If the sound was gear related then everybodies Walboro would make that "jet engine" sound. IMHO if my pump started making that noise then I would replace it. I just can't believe that some people call this sound normal.
Old Jul 2, 2004 | 01:49 PM
erioshi's Avatar
I wonder if people might be over-torqueing the cover back on the tank? That might transmit some extra noise into the body or cabin. I haven't been able to hear my pump above the exhaust yet, but I guess we'll see in a few months.
Old Jul 2, 2004 | 02:00 PM
jump23's Avatar
My walbro is almost as quiet as the stock pump 99% of the time.
But on a few occassions it has gotten really loud. Pretty scary. Quite a few people also have the same issue so I don't think there's anything wrong with the pump. But it sure does make you wonder.
Old Jul 2, 2004 | 02:43 PM
ogvw's Avatar
I cant hear mine AT ALL....... if it is too loud for ya just get a 3" exhaust - that should take care of the noise (you are sure not to hear the pump with an exhaust!)
Old Jul 2, 2004 | 02:53 PM
smokey's Avatar
I have the walbro pump installed on my Evo. It is much louder than stock, but only after i have been getting "on it". It whines when you have been racing around or stepping on it....and it's okay. If you have been racing around and your walboro pump is not making a noise...then you might want to have it checked. All the people I have spoken to say that the noise it makes when it is really running good....(the loud whine)...is normal and that is a sure fire way to know that your pump is working correctly.
If I am just driving normally and not fast at all, then my pump is pretty quiet.
Just my .02 cents
Smokey
Old Jul 2, 2004 | 04:11 PM
freedom's Avatar
Attached is a zip file containing a mp3 of the Walbro pump running on the bench. Notable is the initial sound when the pump is priming. This is what you hear when the key is first turned on. When partial pressure is present the sound stabilizes and goes up in intensity as the line pressure comes up.
File Type: zip
