Can/Will Shiv tune AEM stand alones on Evos?
Purely out of curiousity, does Shiv dyno tune Evos with AEM stand-alone engine management?
What is the difference between speed density and MAS intake sensors?
i am sure he can. tuning is tuning and a guy like Shiv that understands how a car works can pretty much tune any car. also, don't forget that Shiv has used stand alones many times before including the TEC systems which are all MAP.
No problem tuning the AEM ems. No different than tuning a motec, tec3, hatlech, etc,. The difference between MAP and MAF is that MAP calculates engine load by looking at manifold pressure and RPM while MAF actually measures engine load by reading airflow through the intake. The latter is considered a more accurate sensor barring any issues with sensor placement, flow limitations, dumping BOV charge to atmos, etc,.
shiv
shiv
