What came first the flash or the part?
Old Jul 21, 2004 | 06:13 PM
Obsoleteasian's Avatar
My first question is how can you tell the current firmware of your Xede.
Now I am running Xede by itself, but I will be upgrading a few parts such as cams, cam gears basically to stage 1+.
If my Xede isn't to the newest firmware of course I want to get that fixed, and i wanted to get the xFlash to help with the Xede, now best bet is to install all parts and have everything run so, so than send in xede + ecu to get flashed.
I noticed the xflash has 4 versions, one that helps compensate for larger injectors, what if i don't have larger injectors, is that a must get.. soon kind of situation for the 1+ guys.
Old Jul 21, 2004 | 06:20 PM
KK's Avatar
KK
EvoM Administrator
With XEDE you'll want to get XEDEFlash instead:
http://www.vishnutuning.com/xedeflash.htm
with stage 1+ setup you should get XEDEFlash02 which includes:
  • Rev limit Raised to 7750RPM
  • Boost Limit Raised
  • Speed Limit Removed
  • Idle Adjustments for camshafts
Mark
Old Jul 21, 2004 | 06:29 PM
Haha I meant XedeFlash, Im half asleep. But thanks for clearing up what version of xedeflash to get.
Old Jul 21, 2004 | 06:32 PM
KK's Avatar
KK
EvoM Administrator
no problem.
Mark
Old Jul 22, 2004 | 11:41 AM
BOOSTEZ's Avatar
Mark
There was a speed limit on the ecu?
-M
Old Jul 22, 2004 | 12:20 PM
Ludikraut's Avatar
-M
Yep, there sure is [cough] was. Try doing 160 sometime
l8r)
