Car wont start!! urgent. (my daily driver)
Originally Posted by Dyno4mance
Check your MAF plug in your airbox...you may not have clicked it all the way and it's dropped out
Originally Posted by KK
Disconnect your battery for about 10 minutes to let the ECU reset, then try to start the car again.
Mark
Mark
Originally Posted by gnulooks
Disconnect the negative on the battery and hold the brake in for about a minute.
SC~
Ok guys i know im going to get flamed for this but here goes. I used the wrong light green wire and somehow i broke the female adaptor for that particular wire. (off the entire wire itself). now to make matters worse the place where the other green wire goes into the plug is completely f*cked up. So that other green wire area is a complete mess and broken. This is where i really need help. The correct green wire also breaks on me when i try to disconnect from the exede harness. now both my green wires are shot to hell and i can't even put in the plugs to turn the ignition. If anyone lives in SoCal (pasadena) or knows someone that is a professional that can help me, please please let me know. As of now my car is immobilized so can someone tell me what to do.
ouch...this is why i used the fields ecu extension harness. i didn't trust myself to remove the wires from the real harness. i feel for you. hope you get everything straightened out.
vincent
vincent
This is the point where I would call Vishnu up and see how they can help you figure something out. Good luck man...
Tron can also take a look at it at the LA meet this weekend
Yea i talked to david today.
I mainly talked to brian and he helped me a out a LOT. Till about 12 30 in the morning if im not mistaken. THe car runs now but idles at 500 rpm and dies a little. I guess the ECU is learnnig. I just want to thank vishnu for helping out a customer because they really went out of their way to bust thier asses to get my car working. Thanks a ton and id recommend you guys in a heartbeat, no hesitation.
regards,
Anand Muthiah
regards,
Anand Muthiah
