Question after Vishnu Cam gears.
Old Sep 8, 2004 | 06:40 PM
Uther's Avatar
After installing the cam gears, and putting the motor back together. Is the cam gear cover supose to fit, or does it rub the gears.????
Old Sep 8, 2004 | 07:08 PM
Jorge T's Avatar
I just installed mine but left the cover off. iirc somebody said to keep the gears from rubbing the raised circles/lines have to ground off .
Old Sep 8, 2004 | 07:30 PM
Uther's Avatar
I had a feeling that was the case. Maybe I will just leave them off and let the guy that owns the car make the decision.
Old Sep 8, 2004 | 07:46 PM
jj_008's Avatar
Be very careful about leaving the cam gear cover off. You might cut your power steering line if it shifts. A local guy had that problem and it is not cheap to replace.
Old Sep 8, 2004 | 08:00 PM
Jorge T's Avatar
Ziptied to pull it away... thanks for the heads up!
