Tales From the Dyno: 1/22 EVO IXs ecu doesn't like mods
We just tested yet another EVO IX. This one was fully modded with a complete exhaust (dp, cat-back and high flow cat). Running the stock ECU, it put down nearly typical stock numbers. Goes to show that the car doesn't respond to exhaust mods without a little ECU help. Then we reflashed it with a Stg 1 (aka Stg WTF) ecutek map. 91oct. Results were good...
WHP and Torque: http://img.photobucket.com/albums/v4...yo/ERICKS1.jpg Boost and AFR: http://img.photobucket.com/albums/v4...yo/ERICKS2.jpg It's interesting to see that the injectors run static at 7000rpm (notice the sudden enrichment and then gradual linear enleanment from there to fuel cut). This can be covered up by running the car leaner (say 11:1 across the board). But that's a bit too lean for the these cars on 91oct. It's also nice to see how much low end boost response is helped by just remapping the MIVEC table. Cheers, shiv |
these are nice numbers to see. hopefully i will have an exhaust on my car by the time the dyno day at DYNO4MANCE comes around so that I can then say my car is using the stg WTF..lol
Shiv,
Do you think with a boost controller + TBE any good gains can be seen on the IX with the stock ecu? |
Shiv, Do you think with a boost controller + TBE any good gains can be seen on the IX with the stock ecu? oh yes dude!! i have a IX MR and i have a boost controller and TBE, K&N drop in, and it makes a big difference in power also in gas lol "the pump is my bestfriend" |
Wow with just the full exhaust set up I can too see some simular numbers? Don't you need to upgrade the fuel pump for a flash? or you don't need too?
Originally Posted by Doogie Howser
Shiv,
A boost controller will help dyno numbers for sure. But just raising the boost alone will make the car more knock prone. The best way to get those big midrange gains is to MIVEC tuning. Raising boost will only get you 1/2 way there...
shiv |
Troy I was about 50% sure.. ;) |
Thanks for the info, looks like I need a tune. :eek:
Troy I was about 50% sure.. ;) :) |
shiv |
Originally Posted by Cloud
And also are you going to tune them when you come up to WA?
Please PM me with the tuning details/prices and date. Thank you! |
Originally Posted by EVO-IX-MR
Shiv, If you are going to do tuning while you are in WA I would be interested. I have an IX MR with a 3" cat-back.
Shiv,
How does this dyno comparison compare with the difference in power between stock and stock with a tuned ECU? Alex |
stock is 230 and a dyno tuned flash can make up to 270+
| All times are GMT -7. The time now is 02:30 PM. |
