Vivid Racing - Arizona With the best JDM selection of parts for your EVO and a great experience for your EVO upgrading, Vivid Racing is here to answer your questions and needs. [Visit Site]
Full Front & Rear Brake Package!!!
Old Feb 16, 2006 | 01:07 PM
Vivid Racing's Avatar
We have put together a full front and rear brake package for your EVO which includes all rotors, pads, lines, and fluid all in one happy little package!!! Below is a list of all parts included in the package!! The whole package is a total of $974.00 plus shipping. Please PM or call for shipping prices!!!
Rotora EVO VIII Drilled & Slotted OE Rotors
Developed to replace the OE 12.7” front and 12.0” rear rotors, Rotora’s high-performance rotors for the Mitsubishi Evolution VIII are designed to meet the challenges of track and road racing. CNC machined, Rotora’s performance replacement rotors features slotted, or cross-drilled and slotted combination: all are applied to the disc’s front and back surfaces to ensure maximum heat and gas dissipation for greater stopping power and minimize warping and cracking caused by repeated, high stress, high temperature braking.
In exceeding all vehicle manufacturers’ specifications and tolerances, Rotora's performance brake rotors match the vehicle’s OE (original equipment) rotor’s dimensions and are fully compatible with its hubs, calipers and wheels. With an “e-coat” (black) plating finish as an added protective layer to reduce corrosion and prolong rotor life, Rotora’s high-quality and specifications are assured that every component meet and exceed worldwide ISO 9000 quality standards.
Project Mu Front and Rear Brake Pads NS EVO VIII
Street Brake Pad with Superior Initial Stopping Power - Developed specifically for the street, NS outperforms any stock brake pads. Reliable in any weather or road conditions, NS gives outstanding initial stopping power which is a prime importance on the street. In addition to reducing brake dust and squeal, NS helps keep rotor wear to a minimum. Applicable Rotor Temp: (F&R) 0 to 400 deg. Celsius
Agency Power Brake Lines EVO VIII
Agency Power now has a wide variety of steel braided brake line and clutch line kits for most high-end performance cars. The brake line and clutch line kits are made in the USA to meet strict D.O.T. certifications. The steel braided lines are a smoke color with the AP logo printed on it. The CNC machined fittings are in classic Agency Power Gold to separate you from the competition. All kits are assembled for a quit and easy install. Include fittings, hoses, and necessary hardware.
Steel Braided lines improve component performance over the stock rubber hose. With rubber hose, the fluid under pressure flexes the hose, cause loss in firmness and reaction. With the steel braided lines, the response is firmer giving you more control.
Motul RBF600 Synthetic DOT4 Brake Fluid
Extreme thermal resistance and stability.
The elevated boiling point of RBF 600 FACTORY LINE (312°c / 593°F) enables effective braking even under the extreme conditions of competition.
Very efficient in the rain: the very high wet boiling point (216°c / 420°F), is superior to conventional brake fluids and provides a particularly efficient braking system in rain and minimizes the risk of vapor lock.
Old Feb 16, 2006 | 01:13 PM
kmcconn9's Avatar
great price, pm shipped to 21742
