New Agency Power Side Motor Mount - ONLY HERE
NOBODY has this!!!!!!!!!
Agency Power has just release this brand new passenger side motor mount for your Mitsubishi EVO. This full CNC 6061 aluminum mount has a Delrin bushing with a durameter of 88. It includes a steel sleeve to give your engine the firm feel you desire. Improve your drag racing, road racing, and general street driving with this new motor mount from Agency Power. The stiffen mount is much improved over the factory rubber mount. The factory mount has the potential to weaken for extreme high horsepower cars to general hard driving conditions. As well our mount is much stiffer then a urethane insert. The Agency Power passenger side motor mount is a direct replacement. Adding strength, rigidity, and style to your engine. The AP mount fits all Mitsubishi EVO VII, VIII, and IX cars from 2003 and on. It includes new stainless steel hardware, aluminum mount, black delrin bushing, and steel sleeve. Check out this and other AP parts for the EVO at www.agency-power.com.
Buy online here -
http://www.vividracing.com/catalog/v...1_184_186_4383
Intro offer of $130 shipped. Give us a call!
4809663040 x222
Buy online here -
4809663040 x222
I have a few questions for you:
- Are you planning on releasing replacements for all 4 engine mounts? I thought you previously said Agency Power will be releasing 3 of the 4 mounts only. I searched but couldnt find you saying that.
- What grade hardware comes with this? Weird question you may say, but I bought another competitors motor mount that replaces the lower front mount and even though its made from stronger 7075 aluminum it came with grade 5 bolts and washers. That worrys me a little. It should have came with grade 8 hardware at least.
- What about the stock mounts' hole in the top where the A/C or power steering hose bolts to it? Does this leave the A/C or PS line hanging loose? Would this be a problem to leave this line hanging? Mitsu mounted it to the engine mount for a reason?
- Is there a reason you use 6061 aluminum instead of using 7075? I know its a little more expensive. but 7075 is MUCH stronger than 6061. I would think an engine mount would need to be made of the strongest Aluminum available?
Thanks!
Thanks!
