VR Flash Your Evo!
VR Flash Your Evo!
VR Flash Special!
The VR Flash is a great way to increase horsepower with a minimal cost.
What is it?
A reprogram of your factory ECU. It changes certain parameters including: Optimize air to fuel ratio, optimize your timing curve for added power, idle, boost and so on.
What does it do?
The addition of the VR Flash gives you not only more power but also some great features:
* Correct Air/Fuel Ratio - Will increase power and make sure that the car is running reliably.
* Ignition Timing - Modified to increase horsepower as well as maintaining reliability.
* Two Step Launch Control - Available with the Evolution 8/9. This sets a pre-determined rev limit that allows you to hold down the gas instead of having to feather it. Great for drag racing.
* Boost Control - Boost control with just the stock solenoid. Fully programmable and works very well.
What Do I Need to do to Get a VR Flash?
In order to get this flashing done you will need a couple of things:
* Tactrix Cable - This cable can be purchased from http://www.tactrix.com/
* Datalogger - You must get a datalogger for your Mitsubishi. They can be downloaded from either http://www.activematrix.com/ or http://www.enginuity.org/
* Open ECU Software - This is a free flashing software that makes this possible. It can be downloaded at http://www.openecu.org/ ver 1.30 and on is best.
Evo 8 with VR Flash: +15hp and 44ft/lb torque
PM, email, call, or AIM for the lowest pricing!
