0-5v flow output from hfs-6
Old Apr 30, 2009 | 12:17 AM
burnzy's Avatar
Just wondering if someone could help, I know I can get 0-5v flow voltage from either green wire going to the gauge or yellow going to the flow sensor itself however it requires me chopping up the rj-45 cable, is there a cleaner way to do this?
Old Apr 30, 2009 | 12:33 AM
Richard L's Avatar
Yes, the green port (user has this output). You need to get yourself a RJ45 plug. No need to chop the other cables.
Old Apr 30, 2009 | 01:03 AM
Richard L's Avatar
Originally Posted by Richard L
Yes, the green port (user port has this output). You need to get yourself a RJ45 plug and cable. No need to chop the other cables.
PIN NUMBER 5 is the sensor V.
RJ45 orietation:
- tab on top
- cable on the right side of the RJ45
pin #1 is at the top. and pin #8 is on the bottom.
Old Apr 30, 2009 | 02:46 AM
burnzy's Avatar
noice... thanks richard so pin 5 as in blue/white colored? could you tell me what else comes out of the uesr port?
Old Apr 30, 2009 | 06:06 AM
kkarim's Avatar
+1 on the info concerning the user port.
also richard, is there a cc/min to volt scaling we can use, or should it just be considered raw voltage?
Old Apr 30, 2009 | 10:37 AM
Richard L's Avatar
Pin 1 = 12v fused.
Pin 2 = remote ground monitoring (green led)
Pin 3 = Gauge button: 0v = system on (0.5A max).
Pin 4 = W-IDC signal (0-5V). Uncompensated 0.1mA maximum
Pin 5 = Flow sensor signal 0.5 - 4.5V. User calibrated 0.1mA maximum
Pin 6 = MAP Sensor signal send/receive (0-5V) 0.1mA maximum
Pin 7 = Signal ground. (0V)
Pin 8 = F-IDC send/receive (digital)
Use this port at you own risk.
Use this in you
Old Apr 30, 2009 | 07:40 PM
burnzy's Avatar
thanks, hooked up pin 5 to my zeitronix and it logs the flow nicely.
Old Apr 30, 2009 | 08:33 PM
burnzy's Avatar
also is it normal for it to ready about 1.7v on 0 flow?
Old May 1, 2009 | 12:00 AM
Richard L's Avatar
At no flow, it should read 0.53V unless it is influenced by external voltage sources. The extermnl device must be a high inour impedance type.
Does your V-sensor read 1.7v?
Old May 1, 2009 | 05:13 AM
burnzy's Avatar
hmm mine reads 1.7 on on my zeitronix zt-2 which is meant to be high impedence, full flow reads 5v
Old May 1, 2009 | 05:16 AM
burnzy's Avatar
maybe i'm logging the wrong pin, might be logging w-idc? what voltage would w-idc show at 0 flow? should work either way though shouldn't it? w-idc should be equivalent to flow? can you tell me what color pin 5 should be.
Old May 1, 2009 | 07:16 AM
dudical26's Avatar
I can look though my EvoScan settings when I get home and give you the equation I use, but it really needs to be calculated by each person as it will vary based on your scaling of the gauge.
Best way to do it is measure voltage as 0 flow, then measure voltage at full flow. Collect the water sprayed for 30 seconds of full flow. Then weigh the amount of water sprayed (in grams) then multiply by 2 to go CC/min.
Then assume linear scale of voltage from 0 flow to full flow and you should be able to derive the equation.
Let me know if this is not clear and I can give you more guidance.
Old May 1, 2009 | 09:00 AM
Richard L's Avatar
If you have a digital voltmeter, try other pins until you find 0.53v. W-IDC can be anything, depending on the settings.
Old May 1, 2009 | 06:29 PM
burnzy's Avatar
thanks richard, I did in fact have it set on W-IDC, still followed the same graph as I expected flow to be so I didn't realise. it reads exactly .53v on the zeitronix now and peaks at 2.5
Old May 2, 2009 | 01:09 AM
Richard L's Avatar
You can log the W-IDC also. You can check it against the Dud-tool.
Mike Maggio
Aug 9, 2017 04:45 AM
EvoIX89
Jul 14, 2017 12:40 PM
mrfred
58
Jan 4, 2016 06:09 PM
Labonte MotorSports
57
Jul 15, 2009 09:07 PM
fred 62
15
Nov 15, 2007 04:56 AM
